Old 03-06-2016, 10:07 PM   #1
masterlock
masterlock's Avatar
Disc brake help
Ok so I did a rear disc conversion on my 78 k20. Everything fit very tight and the upper caliper slide pin on the passengers side is ever so slightly rubbing the rotor at one point in the rotation. Its probably less than a quarter of an inch where it just barely brushes against the pin. I have tried everything to fix it, even took the rotor off and re-pressed it on.
Question is this a big deal or am I freaking out about nothing?
masterlock is offline   Reply With Quote
Old 03-07-2016, 01:11 AM   #2
tommy217xxx
tommy217xxx's Avatar
Re: Disc brake help
Is something bent? It sounds unusual that it's only rubbing at one point and not all the way around. Maybe a worped roter.
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 03-07-2016, 01:23 PM   #3
slotard
Re: Disc brake help
What kit did you put on? Sounds like something may have been cut wrong.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 03-07-2016, 01:49 PM   #4
masterlock
masterlock's Avatar
Re: Disc brake help
Well the kit was from lug nut 4x4 and it did require some modification on my part so it fits pretty tight. In addition the rotor may be off by a few millimeters but I pressed it on twice and didn't want to do it again. It's literally just brushing against the pin at one point on the rotor. I have a Dana 60 rear end, maybe I need a different bracket but I can't find one any where.
Old 03-08-2016, 02:18 AM   #5
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Disc brake help
Check out ruffstuffspecialties.com They sell kits
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 03-08-2016, 03:36 AM   #6
snaptoo
Re: Disc brake help
Not knowing much about your set up makes it hard to diagnose what your problem could be . I got the D60 axle and assume it is a full floater hub ? Couldn't a guy press the rotor on the hub and have the whole assembly trued ? Sounds like you are having a radial runout problem and possibly an axial one too ! I've done some disc brake swaps using GM 4x4 front calipers and the GM stamped steel caliper bracket , this on an early Ford Bronco as all the parts are Dana to begin with .
snaptoo is offline   Reply With Quote
