Cleaning up my garage sale
PRICES REDUCED! I NEED THIS STUFF GONE SO I CAN BUY MORE PARTS
Cleaned up my garage today and I found a few more parts to sell that I'm not using in my LS swap Gauge cluster - $old Sunpro Super TachII - $old Sanden 508 Ac compressor - $130 shipped PATC cable speedo 28% increase adapter. Worked great for correcting my speedo where the PO installed 3.07 gears in place of 3.73 gears - $old 100 amp internally regulated alternator - $60 shipped ![]() ![]() ![]() ![]() ![]() Last edited by clemsonteg; 06-12-2016 at 10:08 AM. |
Re: Cleaning up my garage sale
Bump
Open to offers also
How about 25 shipped on the speedo adapter?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Bump
Ttt
Prices reduced
![]() Join Date: Aug 2015
May be in line for the speed adaptor ....need to know if it works also 3.42 and the hookup...just looking for info before I buy...thanks...
71 C10 I6 250 TH350 power steering and power breaks... |
Was it leaking when you took it off?
There's nothing to leak. It's just of gears on the inside with male and female threads to go between the trans and speedo cable. It's dirty from my hands and being under a truck for the last 3 years. It came from my working vehicle. Only reason it came out is because I'm LS swapping my truck and using Dakota Digital gauges which means no mechanical speedo
Will it work with a 3.42 gear set...
It will work in the sense that it will fit your trans. Without knowing what gears you had or what kind of change you took on/how hour speedo reads now, I wouldn't be able to comment if it will work. My speedo was off on the low side. I needed it to read faster by over 25%.
#15 |
Yep separate piece I thank you for all your info
#16 |
#17 |
Really ? That's weird because mines leaking oil..I had did some research on this and came across Greg72 post looks like this part number my fix my problem.
Hopefully |
#18 |
This is an adaptor. It is certainly possible that your speedo gear housing is leaking, but that is separate from this piece.
#19 |
i need this stuff gone
#20 | |
I will take the Tach if in Good Working Condition.
#21 |
Worked when I took it out. I'm not using it or my old gauges with my swap since I bought a set of Dakota Digital gauges. Paypal is clemsonteg@yahoo.com
#22 |
Money sent for Tach.
#23 |
#24 |
Bump
#25 |
If the PATC cable is still for sale PM me payment info...
