Old 03-07-2016, 12:19 PM   #1
klwebb
kickdown cable on a chevy 350?
okay, my 1971 c10 w a 350/350 is finally running! sorta. it starts up, runs fine, but isnt responding like it should when im on the gas? if im slowly accelerating and then punch the gas it sputters and dies, but if i slowly accelerate until its on the floor its fine but still doesnt go as quick as it should if that makes sense? i have the kickdown cable installed (mostly) and while it was parked i tried punching the gas and it didnt die, but i had a friend say that the kickdown couldnt be the reason for that. any tips and advice would be awesome. im a 16 year old girl and no one around me knows much about my truck
18 year old girl who loves old trucks
•Previous Projects•
1971 c10 longbed 350/350
1977 Silverado longbed 350/350
1978 K10 shortbed 350/t400 lifted 6 inches on 33s
"LONGBED LIVES MATTER"
klwebb is offline   Reply With Quote
Old 03-07-2016, 12:30 PM   #2
michael bustamante
michael bustamante's Avatar
Re: kickdown cable on a chevy 350?
do you have the vacuum line hooked up on the tranny?
1967custom
michael bustamante is offline   Reply With Quote
Old 03-07-2016, 12:52 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I don't think that is the problem because the transmission would not upshift until the truck was going about 50 MPH . TH 350 or 400.
She might have a vacuum leak on the distributor advance or at the manifold or carburetor. also a brake booster diaphragm.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-07-2016, 12:43 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The two most common reasons for your symptoms are the accelerator pump in the carburetor is bad or out of adjustment, or the ignition timing is off.
Pull the air cleaner off while the engine is off and climb up where you can look down the carb throat, then manually work the throttle and watch for two real good streams of gas to go down into the manifold. If you see a trickle or nothing then the accelerator pump is bad, or the rod for it is out of adjustment.
Loosen the distributor hold down clamp just enough to turn the distributor and turn it clockwise just a small amount while the engine is running and the engine will speed up.
It should perform better, if the timing was too retarded. If you have a timing light you can set the timing where it should be. Probably about 10* BTDC .
If neither of these help you may have a badly worn timing chain and that will also cause acceleration problems.
VetteVet
Old 03-07-2016, 12:55 PM   #5
davepl
davepl's Avatar
Really sounds more like the accelerator pump in the carb than anything. If you had a bad (leaky) vacuum modulator it'd still likely not cause THAT big of a vacuum leak, and you usually wind up sucking fluid in and getting smoke out the tailpipe. So I'd still check for carb squirters.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
