Old 03-07-2016, 04:51 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Bed Side Angle Strip Fasteners
Am I correct in that the outer bed wood is not drilled and the bolts going through the angle strips doesn't go thru the wood?
Old 03-07-2016, 07:50 PM   #2
jayoldschool
Moderator
Re: Bed Side Angle Strip Fasteners
No, the outer boards don't get routed, and go fully under the lip, then the holes are drilled through the board. On my truck, I had to make new angles.
jayoldschool is offline   Reply With Quote
Old 03-07-2016, 08:34 PM   #3
forestb
forestb's Avatar
If your bead wood is routed that way then I would mount it that way. That is the way my original bead wood was mounted but it was not routed just bolted down. When I got my new wood from Mar-k that edge was not routed. It went all the way to the bed sides and I had to drill my own holes in it.
forestb is offline   Reply With Quote
Old 03-07-2016, 08:24 PM   #4
The Rocknrod
Moderator
Alright.
So when Mark-K sells their new wood fully drilled I "assume" they are drilled on the two edge boards.
Old 03-07-2016, 08:39 PM   #5
The Rocknrod
Moderator
So when I buy the Mark-K wood it won't be routed or drilled. Thanks.
Old 03-07-2016, 08:56 PM   #6
jayoldschool
Moderator
Yes. However... it's so easy to do your own wood. You should really consider it.
This took me less than two hours, including unloading and reloading the car.
Old 03-07-2016, 08:56 PM   #7
forestb
forestb's Avatar
All the edges should be routed except for the ones that but up against the bed sides and you will have to drill the holes your self. Mine is a step side. But I would assume it is the same on a fleet. If I were you I would call them they are vary helpful and will tell you all you need to know or you can go on there wedsight that is full of installation instructions.
Old 03-08-2016, 09:53 AM   #8
The Rocknrod
Moderator
My only "perceived" issue is my drill chuck rotating and hitting the bed side when I drill. Other than that I'm golden, thanks guys.
Old 03-08-2016, 11:10 AM   #9
OldChevy61
OldChevy61's Avatar
Why not just mark, remove and drill then install?
OldChevy61 is offline   Reply With Quote
Old 03-08-2016, 11:44 AM   #10
The Rocknrod
Moderator
Because I didnt think of that
Thanks.
Old 03-08-2016, 01:12 PM   #11
forestb
forestb's Avatar
make sure you drill the holes before varnish it so that the varnish will get into the holes that you drill.
