![]() Join Date: Apr 2010
Font inner fender wells
Set of 69 front inner fender wells. Good shape. $80 for the pair, don't want to ship or separate them.
Re: Font inner fender wells
Second pic
![]() Join Date: Jul 2009
Where are you located in Louisiana?
Southwest Louisiana, in Jennings.
![]() Join Date: Feb 2009
Are those OEM? If so and it's not any trouble, can you weigh them? Just trying to confirm mine are original. Someone suggested one might not be, because the hole didn't line up with the nut located on the RH fender pocket.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
I couldn't until this weekend, but if one of your is suggested to not be OEM, weight the two you have and see if they are the same weight. Let me know if You still need to the info
Wade |
I can't answer that, because the LH could be after market as well. That said, the LH side matched up perfectly. Both weigh approx. 9 pounds. If I had to bet, they're original.
![]() Join Date: Jan 2012
will they fit a 71 model ? if so i'll take em . i am just across the state line in Texas and will drive over and get them on my next days off that work with your schedule . i will be off Mon. - Wed . thanks,kenny
This is MY rifle.There are many others like it but this one is MINE. Beware the man who only owns 1 rifle , he probably knows how to use it. |
That'll work, Probably Monday or Wednesday sometime would be best. I'll PM you my cell number and you can text me over the weekend
Thanks, Wade |
