Sway Bar Installation Help...
I will be getting my 1 1/4" front sway bar in a few days for my '70 and my question is, does the front end stay on the ground when they are installed? Thanks Ed...
1970 C/10 350/T5 SWB stepper... 1979 Corvette 350/Auto T-top... 2010 Acura RL... 2015 2500HD Z-71 Silverado... |
Re: Sway Bar Installation Help...
When installing you should have the suspension loaded. If there is enough room you can jack it up with the sway bar end links attached to the a-arms, lower the truck back down, crawl under and lift the sway bar up and mark and drill for the center bushings, bolt up the bushings then tighten up the end links.
The easier option is pulling it onto a set of ramps or something secure for the tires to rest on with some height.
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread |
#3 | |
![]() Join Date: Nov 2004
No drilling required. The holes for the frame mounts are there.
*IF* you want to mount the bar directly to the frame (if you have a lowered truck), then you can drill the holes, or buy an ECE "lowered mount" and use all the stock holes.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
On trucks that came form the factory with a front sway bar. Is the sway bar completely bolted on or is some of it riveted in place. I ask because on my previous truck it didn't have the factory sway bar and when I added it I believe I had to drill out a couple of rivets where the rear of the sway bar bolted up.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#6 | |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
I had looked and never found the answer to my question. There are lots of sway bar install threads but never seen my question asked, answered or explained. Thanks for the info.
![]() Join Date: Jun 2010
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#9 | |
When you install brackets on a non factory sway bar truck, you have to remove the rivet from the cross member to install the rear bracket mount, then a bolt holds the cross member, frame, bracket in place.
