09-24-2003, 02:16 PM | #1 |
What year can i swap out the brakes?
I have a 67 GMC and i wanted to swap out the drums in the front to some disc brakes, what year chevy can i use and it will not require to much modifications?
Thanks, all "Keep on Trukin" |
09-24-2003, 03:15 PM | #2 |
Keepin an eye out
Im in the process right now on my '70. Im using '71-'72 spindles and 71-72 upper and lower ball joints along w/ outer tie rod ends, brake lines and master cyl/ booster. Been working on it for weeks gathering and changing parts, just hope it all works when finished....I think the 67's are the same, someone else my want to chime in, good luck.
Also you want to use the same stuff..1/2 ton to 1/2 ton. 3/4 to 3/4.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 Last edited by boraxman; 09-24-2003 at 03:17 PM. |
09-24-2003, 05:08 PM | #3 |
To bad you aren't closer to Kansas. I'd make you a deal on a complete 5 lug front cross member with discs, spindles, a-arms, springs, calipers and proportioning valve. Won't fit my 6 lug 4x4, bought the truck for some other parts and am slowing piecing it down. Shipping would be a bit much I'm sure. Can you say "road trip"
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
09-24-2003, 05:58 PM | #4 |
Dad's little helper
right now I am in the process of puting my 67 on a 71 frame, something easier to do is find a 71-72 frame/truck and take the cross member and rear axle from in and put under yours, good luck.
too many projects: 61 biscane 67 swb(shaved) 73 Fiat spider 124 Sport 84 Pontiac Grand Prix 86 olds cut. sup. |
09-24-2003, 06:49 PM | #5 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 09-24-2003 at 06:52 PM. |
09-24-2003, 08:06 PM | #6 |
My 69
Had a narrower rear end so I am in the process of making a spacer plate to make up the difference.I t came out around 3/4" shorter on each side of my 69 housing.And yes it was a stock rear end and yes my 72 axles were longer so it was not a direct swap for me like I was told by some . C-YA
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
09-24-2003, 08:25 PM | #7 |
Keepin an eye out
Crazy Longhorn, thanks for the tips....I can deal with grinding the steering stops but hopefully I wont need to deal with the center link.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
09-24-2003, 08:28 PM | #8 | |
Keepin an eye out
Re: My 69
09-24-2003, 09:39 PM | #9 |
Watch out for your cornhole !
Keep on Truckin......PM me if you want to buy a whole disc brake front end for your truck. Complete from rotor to rotor off a 72 Chevy 1/2 ton- 150 dollars. I'm in Fort Worth too.
Kevin
09-25-2003, 01:56 PM | #10 |
Tx Firefighter, can i come and look at that, so i can see how that will work on my truck? Thanks
Thanks everyone for the info, im a visual person so i really cant picture all of that yet but i will have to, cause i want some discs on my truck. |
09-25-2003, 09:52 PM | #11 | |
