Old 03-13-2016, 04:12 PM   #1
mike16
68 k20 carb to aircleaner spacer questions
I have a 1968 K20 with the 327/quadrajet 4BBl . It has a standard aircleaner assembly. between the carb and the aircleaner is a spacer about two inches in height.
does any one have pictures of one I can compare so I get the right one.
I'm shopping for one. seller's ask me if it has a fitting or tube on the side for a PCV valve.... or not. my trucks PCV valve is already hooked up else where. So I'm assuming I need the spacer with OUT the PCV fitting on the side?
Pictures of a correct 4bbl spacer would be wonderfull.
mike16 is offline   Reply With Quote
Old 03-13-2016, 04:59 PM   #2
geezer#99
geezer#99's Avatar
Re: 68 k20 carb to aircleaner spacer questions
It's not a pcv fitting!
It's an air fitting.
To supply filtered air to one valve cover.
Do you have an air fitting/tube on one cover?
geezer#99 is online now   Reply With Quote
Old 03-15-2016, 01:32 AM   #3
mike16
oh! now I dont know. gonna half to look again
