Old 03-14-2016, 06:58 PM   #1
jlolson
jlolson's Avatar
Best 73-80 moldings and trim?
I couldn't find this question answered specifically in a search so I'll ask - Who makes the best exterior molding and trim packages for the 73-80 C10?
Thanks in advance.
jlolson is offline   Reply With Quote
Old 03-14-2016, 09:07 PM   #2
burban nate
Re: Best 73-80 moldings and trim?
Thanks in advance.
I'd like to know this also, will be needing it all for my CC dually project. From what I understand there are only one or two manufacturers doing reproductions.
Nate
Current Project: 1990 V3500 CC dually.
burban nate is offline   Reply With Quote
Old 03-14-2016, 09:31 PM   #3
dragonball98312
dragonball98312's Avatar
Im curious how the lmc trim goes together with oem trim. My front clip and door trim cleaned up nice but my tail gate and quarter trim was missing when I bought my truck.
dragonball98312 is offline   Reply With Quote
Old 03-14-2016, 10:32 PM   #4
Jaysonb
Jaysonb's Avatar
I bought the full lmc kit for my truck, I have not installed it yet. It looks good, but it seems pretty light guage.
Jaysonb is offline   Reply With Quote
Old 03-15-2016, 12:19 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
As far as I know, LMC is the only company that offers the 73-80 trim. I bought some several years back, and it was nothing like the NOS trim I had.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-15-2016, 10:56 AM   #6
allengator
allengator's Avatar
I will need an entire kit for my '80 SWB... so I would like recommendations as well!
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 03-15-2016, 11:27 AM   #7
Tervill
Tervill's Avatar
I purchased mine from www.classicparts.com. Fit was very good and came with double sided tape on sliding tabs on the backside.
Tervill is offline   Reply With Quote
Old 03-15-2016, 12:03 PM   #8
allengator
allengator's Avatar
Did the appropriate pieces use the mounting holes, or was it all double sided tape?
Allengator
Outta the Blue
Old 03-15-2016, 01:42 PM   #9
Tervill
Tervill's Avatar
The kit came with mounting hardware for holes but I just used the double sided tape.
Here is the link to what I bought:
http://www.classicparts.com/1973-80-.../#.VuhKmeIrIdU
Old 03-15-2016, 02:26 PM   #10
mikentosh
mikentosh's Avatar
The issue we've seen with all of the aftermarket trim is the curve around the front marker light on the fenders. The upper part of the curve doesn't follow the fender lines like the OEM trim does. We've also found varying degrees of polish/brightness between pieces even from the same manufacturer.
We've actually ordered a complete set from Brothers, Classic Parts, and LMC and all seem to be from the same source (most came in bags marked with manufacturer name, and some came without any names).
mikentosh is offline   Reply With Quote
Old 03-21-2016, 08:40 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Dang, thats lucky. All I find is bits and pieces at crazy prices. I really want to put a new set on my 77. I have several NOS pieces, but not quite a full set.
Articles-
"Refining Sierra"
Old 03-21-2016, 11:40 PM   #12
mikentosh
mikentosh's Avatar
As mentioned above check the truck and car shop. They have some '77 GM OE stuff listed still. We were actually thinking of maybe going the '77 route with my project so I was browsing for the yellow trim too
Old 03-23-2016, 08:07 AM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
I will check that out. I can tell you trying to find 77 trim is very hard, and expensive. Unless you find a full set from one source, the probability if it all matching is slim.
Articles-
"Refining Sierra"
Old 09-26-2016, 01:23 PM   #14
jlolson
jlolson's Avatar
To close this thread out. I ordered my trim from classic parts. In general it was pretty decent and looks good. Pro's: Includes all appropriate fasteners, nice shine, fitment was good in terms of length and width. Cons: trim is thin, included fasteners need to be trimmed in some cases to match pre-existing holes in the body, double sided tape mounts do not secure the trim flush to the truck and don't have fantastic adhesion, had to supplement with 3M stuff in some locations.
Old 09-26-2016, 07:15 PM   #15
75C10
If I may add my comments. I installed a full set on my 75 and the following were my observations.
1. Curved front fender molding fit so poorly I elected to used some original pieces even though the molding finish does not match. It only shows in some light and certain angles.
2. I wouldn't use the metal clips at all. The centre posts on several of mine were loose and removal was difficult. Some of the clips had no "spring" and when inserted into the correct size holes there was no tension to keep them in place. Use original clips if nec or seek out better clips. You will need 5 or so for each front fender. I used no clips any where else - just extra tape and GM plastic moldings along with the screws that the moldings also come with. So far so good.
3. I used the plastic clips with the two sided tape installed and so far I have removed most of the moldings and re-installed them with fresh 0.030" two sided tape. They all came loose. I used isopropanol to prep the paint as well as grease and wax remover. With good tape this procedure works good. You can also use and adhesion promoter. The moldings fit much better (tighter to body) with the thin two sided tape. Use 3/4 inch wide tape. Save yourself some grief and time and don't use the tape they come with. Spend the money and time and use reliable two sided tape.
4. The repro moldings are not perfect but after inspection of many factory installed moldings I would say the GM moldings were not perfect either. I have no experience with NOS parts.
BTW the moldings are easily removed using fishing line. No damage to paint.
Darwin
75C10 is offline   Reply With Quote
Old 09-26-2016, 07:43 PM   #16
gmachinz
I have nearly (1) full set of exterior dual trim for a 73-80 longbox and an extra pair of LH/RH Shortbox pieces too. The only ones I'm missing are the 3" ones that go on the cab just before the doors. It is tuff to find them all-all of mine I've had for 22+years but them dang small ones I'm missing!
gmachinz is offline   Reply With Quote
Old 09-27-2016, 08:58 AM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
Regarding NOS side molding, I can tell you it's not much better than what's on the market in appearance. The aftermarket is much thinner and the sheen is different, but at least it matches.
I have several pieces of NOS 77 and more 73-80 and it's not perfect in color or sheen either.
Articles-
"Refining Sierra"
Old 11-18-2016, 04:24 PM   #18
Coursey
Coursey's Avatar
It was suggested to me to call LMC and ask for "Motowell Trim", not sure what the difference is, I assume it is a brand?
Coursey is offline   Reply With Quote
