Old 03-16-2016, 12:08 AM   #1
Pampas56
TH 350 Odd Slippage
I just finished up replacing the transmission in my 84 C-10 and it runs fine and shifts great. The only issue is that when I first start it up it won't go into gear unless I rev the truck for about 5 seconds in gear. After that it is fine until I shut the motor off, then I have to go through the same routine all over.
I don't want to have to pull the tranny again if I can help it. It seems to me that the pump and converter both work fine and the internal parts are OK, but something is not letting me build pressure at idle.
Does anybody have an idea of what simple/stupid thing that I am missing?
Fluid and filter are new and fluid is at the full mark.
1989 Silverado K2500ECLB- 307K miles with 90 K TBI 350-Not a show truck, a work tool that I can drive!
1998 Dakota EC 250K miles- I guess I'm just a truck guy now!
Pampas56 is offline   Reply With Quote
Old 03-16-2016, 01:08 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: TH 350 Odd Slippage
You say fluid it's at the full mark is the after it warm up and running?
Because it sound like low fluid. or filter maybe out of place.
If the two things are ok then something in the trans sticking.
Oh by chance do you have a trans cool on it. If you do make sure there no air traped in the lines.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-16-2016, 09:14 AM   #3
cadillac_al
My K20 plow truck has been doing this for a few years now. It is kinda scary and makes me think the trans is on the way out but once it kicks in, it is fine. It does seem like something sticking. I never believe in snake oil but I have heard accounts of people fixing some tranny oddities with Lucas trans conditioner or something like that. If I was going to try some snake oil, which I might, it would be the Lucas. I'm hoping to find a simple answer too.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
