Old 03-16-2016, 10:23 PM   #1
1redbowtie3
1redbowtie3's Avatar
Firewall Insulation Pad
Anyone replace one? Any tips would be appreciated ..
1985 K20 4spd
1978 K20 4spd
1redbowtie3 is offline   Reply With Quote
Old 03-16-2016, 11:01 PM   #2
bbbc10
Diggin The SquareLife
Re: Firewall Insulation Pad
Most ppl dont run them from what i seen....u will see someone now an then with one
bbbc10 is offline   Reply With Quote
Old 03-16-2016, 11:07 PM   #3
Pontiac1976
Pontiac1976's Avatar
You have to have a lot of stuff out. Do you have a/c or not?
WO/AC is less work
I still try to find a none /ac pad.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-16-2016, 11:17 PM   #4
GSOUTHERN
Active Member
To put it in correctly you have to have pretty much everything out from under the dash. I just tried putting one from LMC in my 83 with a/c and could not get it to fit right at all, I'll make you a good deal on it!! I ended up getting one from somewhere else and it worked good, I will post tomorrow where it came from, I can't think of it right now
GSOUTHERN is offline   Reply With Quote
Old 03-17-2016, 07:38 AM   #5
chrismoore701
chrismoore701's Avatar
I put a double layer of that foil insulation from Home Depot up there
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 03-17-2016, 10:06 AM   #6
1redbowtie3
Well that's kinda what I thought just glancing at it, lots of labor .. thanks, I think I'll look into alternatives.
What are your impressions of the foil?
1985 K20 4spd
1978 K20 4spd
Old 03-17-2016, 10:32 AM   #7
GSOUTHERN
Active Member
USA1 Industries Inc is were I ordered the insulation pad that fit really good
Old 03-17-2016, 09:25 PM   #8
Pontiac1976
Do you if they sell none a/c pad
Old 03-17-2016, 09:33 PM   #9
GSOUTHERN
Active Member
I believe they do sell the non a/c pad
