Old 03-16-2016, 10:51 PM   #1
Clavo106
any one repair kinks and dings on frame. to straight it out?.
Well i got the hole frame stripped down so I can blast and trying to take out the trans x member.. and I have a kink that the p.o. have used a jack on c channel lip where it drops off rear of Trans x member ..i belive he Jack it obviously in the wrong place and just bent up the lip on one the c channel one side where it drops. off.I Would like to straight thing out the best way possible with out any damage.. was think cut the bottom lip area out in a square and welding in a new piece or doing three relive cut in the frame bent area. And bending back flush.. also a have o/a tanks but don't like to use that 4 any frame work..any suggestions with this topic?
Clavo106 is offline   Reply With Quote
Old 03-17-2016, 12:13 AM   #2
GruntMoanCough
GruntMoanCough's Avatar
Re: any one repair kinks and dings on frame. to straight it out?.
Should be able to straighten it out. A pic or two would be helpful.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 03-17-2016, 07:00 AM   #3
Grumpy old man
Grumpy old man's Avatar
A little heat and the largest Cresent wrench you have should bring it back to where your happy with it without cutting anything .
Old 03-17-2016, 09:04 AM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
x2 on the crescent wrench, if it's big enough you shouldn't even need any heat. It's what I used to fix similar issues on my frame.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-17-2016, 09:15 PM   #5
Clavo106
Yes thanks. Thanks to all ur guys input!!! ...
Old 03-17-2016, 11:01 AM   #6
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
^ These dudes got it right. I have a 4' long crescent wrench just for straightening frames. Just the weight of it will do the trick sometimes with a little heat in the right spot.
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 03-17-2016, 11:35 AM   #7
burnin oil
Great advice on straightening. Be careful on the heat. It can change the metal a little and cause a weak spot. You see this come up a lot when people want to cut, weld, or extend a frame. Done properly it is not a problem. Excessive heating is definatly a problem. Use what is needed and no more and you should be happy with the outcome.
burnin oil is offline   Reply With Quote
Old 03-17-2016, 11:43 AM   #8
Grumpy old man
I get a little crazy about how the frame looks . To me it's just as important as a fender /door . What drives me nuts is watching someone bolt thousands of dollars of brand new suspension to a rusty/greasy/bent frame ??? End of rant
Old 03-17-2016, 12:42 PM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
I'm the same way
Adam
Old 03-17-2016, 11:50 AM   #10
davepl
davepl's Avatar
Most frames are pulled cold. I don't know, but I wonder how much heating up the metal changes the annealing or hardness. It's mostly a curiosity unless its around a mount point, but at a mount might heat change the metal properties?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-17-2016, 12:12 PM   #11
Bagd72Chevy
C10 Collector
Im not sure if C10 frames were heat treated from the factory. Probably not. They were most likely cold worked with tightens the grains up making them a bit harder and stronger than hot worked steel. Problem with this is if you put excessive heat into the rail the molecules will spread and you will get a hicky/lump where you heated it. Dont let the frame become more than a soft orange between the wheels, thats where you need the most strength. At the ends around bumper mounts and such heat as necessary to get it straight. You could also quench if you need to shrink it some but be careful as you can make it too hard and make it prone to cracking.
With the way these frames were made with all the rivets they are pretty fluid and I wouldn't be too concerned with put a little heat on it but dont get crazy.
///Ryan
1971 Blazer - Rusty
Old 03-17-2016, 02:21 PM   #12
davepl
davepl's Avatar
That's one rigid looking frame! Nice.
Old 03-17-2016, 06:15 PM   #13
Clavo106
Thanks it worked! Nice little trick to know..
Old 03-17-2016, 07:36 PM   #14
Grumpy old man
Thank you , Thank you very much, We'll all be here all week !
Old 03-17-2016, 03:16 PM   #15
burnin oil
That is purty. Don't look at mine though. She is a daily driver and part time work truck this rebuild. Maybe in a few years the undercarriage will get some love but until then you can still see where the fire department welded a full cage to the frame. I cut it off as close as the sawzall would get and called it good. I still have people tell me how good it looks and have someone try and buy it at least once a month. I guess being a 4x4 people expect it to not look brand new.
