03-18-2016, 09:58 PM | #1 |
BlahBlahBlah
Reason behind extra tanks?
So the K20 I recently purchased from board member Livrat has three tanks. Cab tank and two extra poly type tanks. I never really gave it much thought before, but why did they have the extra tank option?
I guess I could see it if you were hauling a camper somewhere. But I was thinking these trucks were purchased to use as trucks back in the day. I don't think of them being used to make long road trips. Run low on gas in the regular tank ... stop at the gas station and fill it up. The one thing Ive thought would be an interesting idea is to ditch the in cab tank and run off the two extra tanks instead. Hassle though filling em both up with the fillers one on each side of the bed.
03-18-2016, 11:15 PM | #2 | |
Re: Reason behind extra tanks?
03-19-2016, 12:30 AM | #3 |
Farmers don't go to town every day.... It is 8 miles from my house to the nearest gas station.... Fill them all up and your good for a while before your next trip.
03-19-2016, 12:34 AM | #4 |
Back then there wasn't as many interstates and gas stations, camping across the other side of the state? or a couple states over? 8 miles per gallon? Give me capacity..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
03-19-2016, 04:00 AM | #5 |
I had 50 gallon capacity in an old K10 I used to have, the BB got 8mpg or less depending on terrain. I would easily burn through that on a 2 day off road trip so I also carried 2 5 gal gas cans just to be safe. Ill tell you there are NO stations out in the boonies and god forbid you rupture a tank on some rocks!
03-19-2016, 06:03 AM | #6 |
Extended cruise range. These trucks were used for everything trucks are used for today. These trucks hauled campers all over the nation, towed boats, race cars, travel trailers, etc. Hauling loaded into the wind in some trucks can cut your range down near 100 miles. I've been in areas where a ranch is 50 miles from a gas station. Half a tank drive home with little more than enough to go back for more. It was pure practicality and the reason that ever since we have had a dual tank option, then much larger tanks offered on pickups.
I've often considered just running the saddle tanks. I dealt with a tank on each side in 73-87 trucks for years. Not that bad. There's always the option of only filling the one side, if doing both sides is inconvenient. You would have the 30 gallon capacity, room behind seat, still have a place for the spare tire, and 100% bed capacity. I like the screw-on doors for the period accessory look. But if they bother you, gas filler doors could be grafted-in for a finished look.
03-19-2016, 01:51 PM | #7 |
My truck was originally sold with a big slide-in camper and 2 aux. tanks. I guess total fuel capacity was a little more than 40 gallons. Figuring the 351 V-6 got about 8 m.p.g. loaded with a 4:10 gear, that's about a 320 mile cruising range.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
03-19-2016, 04:10 PM | #8 |
If you were old enough you would remember the gas shortages of the early 70's . Most extra tanks were installed as a solution to the shortage back then.
03-19-2016, 07:50 PM | #9 |
From the mid 60's to mid 70's almost 50% of all 3/4 tons were originally purchased as recreational vehicles. Before this period, yes, most of these trucks were mainly used for business, government and agriculture use.
03-19-2016, 08:19 PM | #10 |
The lack of gas stations on every corner back then was the biggie. I can tell you from past experience a cross country trip (or just to town and back in a big and open state) in one of these trucks with only the cab tank can make you a little nervous. Middle of Wyoming in the middle of the night theres not much for gas stops. I would of loved to had about 5 tanks on my truck.
03-20-2016, 05:12 AM | #11 | |
it would depend on when the tanks were installed and what was going on economically at the time. And even that does not cover all the reasons people put tanks on thier trucks. My 68K20 has the saddle tanks, They were installed shortly after the truck was purchased in late april of 68. the reason being that the owner was always up in the mountans looking for gold and had a bad experience. You think finding an open gas station in Wyoming at night is bad, try the Huachuca Mts.,,, in the sixties. I remember when diesle's first came out, it was such a PITA to go down on the interstate to get fuel. people had the standard tank, then spare tanks every where else on the vehicle and one guy had a 55 gallon drum of fuel sittng in the bed of his truck. |
03-19-2016, 08:23 PM | #12 |
BlahBlahBlah
I guess Im only considering it from the point of view where I live. Lots of valid reasons posted. One side of mine has the screw on cover, the other a cap protruding out of the bedside. I have a 67 parts truck that has two tanks, both steel. You fill them from inside the wheel well.
03-19-2016, 08:35 PM | #13 |
Yes location is a factor. Here in Indiana you saw very few trucks with extra tanks on them
03-19-2016, 09:02 PM | #14 |
I agree with location, here in the tri state region, you never saw or see multiple tank trucks. It was over populated then, with many gas stations to choose from.
03-19-2016, 10:36 PM | #15 |
I sure liked the saddle tanks in a past '67 I had. I could fill all the way up in Salt Lake and drive clear to Reno heading west, or Cheyenne to the east. (actually, I'd fill up just across the border in Evanston, Wyo-gas has always been cheaper there than in Utah)
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
03-20-2016, 02:39 AM | #16 |
I got rid of the in cab tank and run the two saddle tanks..
03-20-2016, 05:12 AM | #17 |
A lot of years ago I remember a sign on the 40 west at Needles California.."Last Gas until Barstow" .. That's when you appreciate three tanks.
J.
1972 Custom Deluxe Highlander C20 1971 Javelin SST New Project 1971 Demon 340 1969 SS El Camino 1968 SS RS 396 Camaro 1967 Barracuda Formula S 1965 140/4sp Corvair Monza Convertible Sorry, but I don't do Fords. |
03-20-2016, 05:21 AM | #18 |
I had no AC in my ElCamino, and I tried driving at night during a cross country trip..
I found out fast that a lot of gas stations west of the rockies would close at night, leaving me sitting waiting for it to open in the morning. After that I always carried an emergency tank.. just in case.
03-20-2016, 06:00 AM | #19 |
While we're on the subject of 3 tanks.
I have a question. I see a lot of the aluminum door tanks on the drivers side. I have the gas filler on the drivers side, and the aluminum door on the passenger. If so does that mean the driver side is a factory addition, and the passenger dealer? Or is it typical for the factory to do the three tanks this way? J.
03-20-2016, 03:28 PM | #20 | |
All about them Ks
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20s |
03-20-2016, 04:07 PM | #21 | |
When I got it home and was able to discover it more, I found it had a few additions that led me to believe it may have been a forestry truck. But the siren was the main give away. J.
03-20-2016, 04:16 PM | #22 |
i'm from long island originally too...sure there were plenty of stations but in the early 70's almost all were 2-bay repair shops that also sold gas....and they closed early...if we needed gas after midnight there was only one station on the parkway that was open and it wasnt cheap....you have to see if the siren is hot wired to a dash knob or tied to door switches cause "on guard" brand car alarms used the same siren...my 69 camaro had one
1970 short step c10 leaf spring 454 Last edited by volksworld; 03-20-2016 at 04:23 PM. |
03-21-2016, 12:54 AM | #23 | |
It's not a newer siren, as it sounds like the typical siren of the 60s 70s. A slow gyrating wail. I believe sirens on street cars is illegal. I didn't remove it, but I did rewire the horn to work normally. J.
03-21-2016, 05:49 AM | #24 | ||
03-23-2016, 10:33 AM | #25 |
Active Member
I have a 72 C20 with the factory tank on the driver side. Not only was the tank factory, there is a switch in the instrument panel that changed the gauge from one tank to the other.
72 Sierra Grande 2500 BB 72 Sierra 2500, 42K miles, factory buckets 72 Cheyenne 20 72 Chevy SWB, Factory BB, Leaf Spring |
