Old 03-21-2016, 10:09 AM   #1
Vanhalen1985
How do I tie accessory wire into fuse box?
On my original 72 fuse box. I need to run a hot wire (hot when key is on) for my electric choke on edelbrock. What is the right way to do this? And how to I do it?
Vanhalen1985 is offline   Reply With Quote
Old 03-21-2016, 12:51 PM   #2
jdalexa84
Re: How do I tie accessory wire into fuse box?
With a fuse Tap like this one
jdalexa84 is offline   Reply With Quote
Old 03-21-2016, 02:10 PM   #3
mgore68
mgore68's Avatar
There should be a male post that is hot only with the key on. You can get a cheap tester and find the correct one or it may be marked. You can crimp a female connector on the wire and it will just slide on the flat post. I have my choke and stereo on this one line.
mgore68 is offline   Reply With Quote
Old 03-21-2016, 06:52 PM   #4
jdalexa84
You can get these at O'Reilly auto parts
Old 03-21-2016, 07:29 PM   #5
ray_mcavoy
^^ Yes, here is a pic of a fuse box (borrowed from elsewhere on this site) that shows the original labels:
Either of the 2 terminals marked "IGN. UNFUSED" would be suitable for powering an electric choke. However, since they are unfused, I would recommend adding an inline fuse to the circuit being added.
ray_mcavoy is offline   Reply With Quote
Old 03-21-2016, 07:25 PM   #6
swamp rat
swamp rat's Avatar
Learn something new every once and a while....
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-21-2016, 10:01 PM   #7
jondancer
Good info
jondancer is offline   Reply With Quote
Old 03-22-2016, 09:19 PM   #8
70STOVEBOLT
70STOVEBOLT's Avatar
I ran a wire from the IGN unfused terminal on the fuse block to the firewall bulkhead connector behind the fuse block in a spot that was not being used and then ran a wire from the bulkhead connector on the engine side of the firewall in the corresponding unused spot to the hot terminal on the choke. I also put an inline fuse holder in the wire between the fuse block and bulkhead connector. If somehow the hot wire gets melted and shorts out, I don't want to burn my truck to the ground. I just ran the ground to a valve cover bolt. I can take pics if you want to see how I did it.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 04-15-2016, 10:56 PM   #9
jondancer
Could I use the radio or cig to power some gauges that light up?
Old 04-15-2016, 11:02 PM   #10
70STOVEBOLT
the cig lighter terminal is hot all the time so your gauges will ways be lit. You can use the radio fuse or the panel lights fuse. Those wil only be hot with the key on.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 04-15-2016, 11:06 PM   #11
jondancer
Thank you
Old 04-15-2016, 11:51 PM   #12
custom10nut
custom10nut's Avatar
Not meaning to eavesdrop, but which terminal would be best to power my courtesy lights with the door jamb switches? Constant hot or key on hot? I haven't installed them yet, but will be soon. I'm thinking constant
custom10nut is offline   Reply With Quote
Old 04-16-2016, 09:36 AM   #13
70STOVEBOLT
The door switches wire into the done light circuit. They piggyback onto the connector below the fusebox. The white wire connected to the jamb switch actually grounds the circuit.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 04-16-2016, 08:46 PM   #14
custom10nut
Thanks for the info. These fuse taps are available at o Reilly's, but you have to order then . Napa also has them, but they keep them on a display in the store. Four in a package for $4. Hope this helps
Old 04-16-2016, 09:29 PM   #15
davepl
davepl's Avatar
I like to ground mine through a relay triggered by the oil pressure sender. That way it won't heat & open the choke just because the key is on, but rather, needs to be actually running for the choke to heat.
I probably wouldn't go to that length JUST for the choke, but if you've already got an idiot light sensor (doesn't work with a gauge sender), it's a simple mod.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
