Old 03-21-2016, 11:44 AM   #1
Blake_496
Intro and question about towing with a C35 one ton
Hey everyone! I am moderator of fsjnetwork.com where we talk about the old full sized jeeps. I built a '78 J10 Honcho a few years ago into a rock crawler and now I have built a '75 GMC C35 one ton 2wheel drive dually so I can tow the Honcho. My Dad actually had the exact same truck that he bought new in '77. Same color and everything. He had that truck on the farm and it rusted out a few years ago though.
I installed a 2005 8.1L L18 backed by a new gearstar 4L80E tranny into the C35. Swap notes include the following:
stock radiator
stock starter for a 454
stock headers for a 454
stock engine mounts
stock transmission crossmember that I moved to the rear position because the 4L80e is longer than the stock TH400
The truck is a 100% rust free Colorado truck and is in amazing condition. It rides and drives great. No issues with it at all.
My question is surrounding towing capacity. I've recently completed the truck and bought a 34' gooseneck trailer with the intentions of towing my rock crawler and maybe another rig if needed. The trailer weights 4600lbs and the J10 weights 6000lbs. I have a new B&W GN hitch (the one rated for 30K). I loaded up the jeep this weekend and took everything for a test drive. All went well, but I could definitely tell the trailer/truck was back there.
What is the max towing rating for these old C35's?
Blake_496 is offline   Reply With Quote
Old 03-22-2016, 12:04 PM   #2
slimneverdies
slimneverdies's Avatar
Re: Intro and question about towing with a C35 one ton
Welcome to the site,
Your year truck GCW will depend on the rear gear that came stock. If it's a 3.73 it's 13,000 and if it's a 4.10 or 4.56 than its 15,000. You should also have trailering special GCW name plate right next to the window molding on the door if it's a trailering special model...
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 03-23-2016, 07:06 PM   #3
SilverMiner
SilverMiner's Avatar
According to the 1975 Chevrolet Truck Vehicle Information Kit from the GM Heritage Center website, there were three GVW ratings for the 1975 C30; 9000 (standard), 9600 (Camper Special RPO Z81/Z83), and 10000 (Dual Rear Wheel RPO R05). Tire sizes determined whether higher GAWR axle rating were given rather than gearing. To achieve the highest GVWR of 10K the RPO J55 HD Power Brakes had to be selected as well. Neither the Vehicle Information Kit or the sales brochures make any mention of GCWR, only GVWR.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 03-23-2016, 07:19 PM   #4
Firebirdjones
Here you go...GCWR in pounds by axle ratio
Firebirdjones is offline   Reply With Quote
Old 03-23-2016, 07:26 PM   #5
Firebirdjones
Speaking 1 tons with a 454 it looks like
3.73's = 13,500 lbs.
4.10's = 15,000 lbs.
4.56's = 17,000 lbs.
Old 03-23-2016, 07:37 PM   #6
SilverMiner
Well sure, if you jump to the 1978 data. Given the minimal changes from 75 no doubt the info is applicable, but it's not the GM gospel for the OP's model year.
Old 03-23-2016, 07:44 PM   #7
Firebirdjones
Isn't much GM says I'd take as gospel but it's a pretty safe bet those trucks went virtually unchanged from 73-79 so I wouldn't have a problem applying that chart to any of those years.
Old 03-22-2016, 12:45 PM   #8
daddyjeep
daddyjeep's Avatar
That's a good looking combo there Blake. When I get my 85 Crew in good enough shape I will be dragging my crawler out to your neck of the woods.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-22-2016, 01:27 PM   #9
burban nate
These old trucks aren't quite as heavy as newer ones, which causes it to feel like the trailer is pushing you around. For comparison sake after I bought my '90 V3500 crew cab I took it to the scale empty and it was right about 6500#. Shortly there after I took my dad's '97 k3500 crew cab to the same scale empty and it was just over 7500#. Both trucks are 454 automatic trucks. The '90 had the Dana 60/70 combo with the NP205 transfer case. The '98 had the ifs and a corporate 14 bolt rear end and the aluminum chain drive t-case.
You have the power with the 8100, I just think the lighter weight of the older trucks makes a huge difference.
Nate
Current Project: 1990 V3500 CC dually.
burban nate is offline   Reply With Quote
Old 03-22-2016, 10:35 PM   #10
Burbnasty
I have no answer to your question... However that is such a badazz combo, that whatever small towing disadvantages you may be experiencing you make up for and then some in style points!!
Burbnasty is offline   Reply With Quote
Old 03-23-2016, 01:45 PM   #11
rumblebox
What accessory set did you use for the swap? I'm seriously considering an 8.1 swap with an allison or NV4500.
74 K20, 454, SM465, NP208, 14FF, D44
14 Silverado 5.3
07 Victory Hammer, Bassani, intake, auto-tuner
00 Formula, 6.0, LS3 heads, X-pipe, etc, etc, etc - SOLD
rumblebox is offline   Reply With Quote
Old 03-23-2016, 01:54 PM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
Had a '86 1t with a roll back bed, and pulled a 24' open car trailer.
454 4 speed 4:10 gear doug nash od
Have had 2 '55 caddys on it. About 22k or so, Pulled it fine, stopping however not so much. Still 300k+ in it.
Old 03-23-2016, 04:35 PM   #13
Firebirdjones
I believe Slim is spot on with the GVW's vs gear ratio. I have a 79 1 ton 454 with 3.73's and 13,000 GVW is what I recall.
I've pulled my 28 foot enclosed across country with it. Empty the trailer is almost 5,000 lbs., had a 4100 lbs. car in it, air compressor, generator, complete 5 foot tall tool box packed with tools etc... Every bit of 10,000 lbs. if not more and it did a fine job pulling it around.
Old 07-27-2021, 03:50 PM   #14
kipps
There's two things you need to worry about. What's legal to tow, and what's safe to tow.
Legally, you can't exceed the truck's GVWR. That's the weight on the two axles of the truck, including trailer tongue weight, but not including weight on the trailer axles. I'm almost certain you're good to go there.
Safe towing capacity is based largely on how the rig feels when driving it. If you're comfortable doing what you're doing, that's the most important thing.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 07-27-2021, 04:46 PM   #15
Dead Parrot
As long as everything is in good shape and you don't bust the GVWR, the truck is doing what it was designed to do. But except for the new parts you swapped in, that truck is ~47 years old. You should keep in mind that on a steep rough road at altitude, things can go from great to crap really fast. Going down that bumpy hill with 16k and finding out you forgot to connect the trailer brakes.... (or a mouse chewed on some wires to the same effect).
Dead Parrot is offline   Reply With Quote
Old 07-27-2021, 04:58 PM   #16
Keith Seymore
Keith Seymore's Avatar
While I appreciate the sentiment(s), please be reminded we are talking about GCW (Gross Combined Weight), not GVW (Gross Vehicle Weight). The GVW is highly visible, whether on the SPID label or on the placard, but the GCW is a bit more nebulous since it varies by rear axle ratio.
Originally Posted by Blake_496 View Post
I ended up putting in 5.13 gears in the stock D70HD (on stock tires) and that really helped getting loads of water and materials up here.
Now here is my question based upon this rig '75 GMC C35 2wd with an 8.1 /gearstar 4L80E / 5.13 gears and detroit. Otherwise stock truck on stock springs.
On one hand, you are in uncharted territory since the factory did not offer the 5.13 rear gear. On the other hand, you are inside the 17,000 lb chassis limit (the highest rating shown on the chart) so you should be ok.
Having been the one that established the trailering rating for some of these vehicles I can say the limiting factor was the ability to launch the vehicle at GCW up the 16% grade. There were a number of combinations that would have been rated higher if it were not for this particular requirement.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-27-2021, 05:10 PM   #17
Blake_496
I don't tow anything DOWN the mountain. It's always UP the mountain.
The truck drives and handles and brakes great when loaded. I only have the Gooseneck. No bumper pull.
I guess I worry about the integrity of the leaf springs and the frame. They all look good, but ~46 years is a long time.
Old 07-28-2021, 03:19 PM   #18
Keith Seymore
My trips feel like they are uphill both ways as well.
K
1979-1986
1986 - 2019
Old 07-28-2021, 12:45 AM   #19
kipps
Is gross combined weight rating even legally enforceable if it's not written on the vehicle anywhere? Are DOT officers expected to scrounge up 40 year old sales brochures to find the critical numbers?
As far as I can tell, the only number that matters to law enforcement is the GVWR. I welcome correction though.
Edit: Was the GCWR a legally binding thing back in the squarebody days? It looks a lot more like a factory "recommendation" that might affect warranty claims at best. After all, there's nothing inherently unsafe about towing a heavy load with a 3.42 axle ratio. DOT doesn't care how heavy towing affects your drivetrain. They just want to know your chassis, tires, and brakes are big enough.
Old 07-28-2021, 03:16 PM   #20
Keith Seymore
That is an excellent question, and I do not know the answer. It is hard enough for us enthusiasts to find, so I wouldn't expect law enforcement officers to have this arcane knowledge.
Correct.
My point was that GVW and GCW are two different animals.
That was my point. The chassis, tires and brakes don't change with the rear axle ratio. The only thing the axle ratio affects is launchability.
K
1979-1986
1986 - 2019
Old 07-28-2021, 03:20 PM   #21
kipps
To some degree, it also affects the amount of stress on the engine and transmission. A 3.42 will run a higher risk of clutch damage than the 4.10 ratio will. Lugging an engine is not good for its longevity either.
Old 07-28-2021, 05:05 PM   #22
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
make sure you have a heavy trans cooler if its automatic and make sure you have a good trailer brake unit
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
