03-21-2016, 03:46 PM | #1 |
upper rad hose Ls swap
I'm putting an ls with a corvette waterpump in a 67 C10 along with a Champion Radiator that has the upper rad hose on the Drivers side. The water pump being from a corvette has the hose coming out the front. A corvette upper rad hose almost fits, except it is too small to fit the rad.
Has anyone found an upper rad hose that will fit this combination? |
03-23-2016, 08:43 AM | #2 |
Re: upper rad hose Ls swap
No one has figured out a hose for this, or is everyone using the truck waterpumps?
03-23-2016, 08:58 AM | #3 |
I usually end up finding a straight spot in the hose, cut, add a piece of pipe, and find another radiator hose that I can cut to make the side for the radiator work.
It's a pain, but I also drill and tap a hole in that piece of pipe for the steam vent tube. |
03-23-2016, 09:23 AM | #4 |
I used the old LS hose and made it fit. This is when the upper outlet was on the driver side and also when I later switched to the outlet on the passenger side by recutting the same hose.
03-23-2016, 09:59 AM | #5 |
I will get you the number for the hose I used later today. I bought it at the local autozone. I just had to cut the end and then flare it a bit to fit over the radiator inlet. I am using and f body pump and a champion rad. I will also post a pic of it.
03-23-2016, 10:14 AM | #6 |
Thanks for the reply's
OldBlue sounds like you have the same setup as me. The part number and a pic would be much appreciated. |
03-23-2016, 10:23 AM | #7 |
Soak it in hot hot water for 5 min, this will make all the difference. It will fit.
1972 C10 - It might be old, but it's not slow |
03-23-2016, 10:27 AM | #8 |
I was going to suggest the same thing DBK81 said. Even the one I bought needed cut and expanded. Hot water will get it flexible and it will slip right on.
03-23-2016, 12:45 PM | #9 |
I'm going to swap over to a Ron Davis radiator due to this (I don't want a really long radiator hose that would result from transporting the coolant all the way to the other side) and the steam vent stuff. But I'd be curious to see a pic of anyone who's done it (well, of the rad, not the person).
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
03-23-2016, 04:52 PM | #10 |
Here are pics of my upper hose. 71425 at autozone. Also note that my engine is moved back as far as the slider mounts would allow.
03-23-2016, 05:40 PM | #11 |
Not sure if it'd clear my planned accessory drive, but that's not too bad!
03-23-2016, 05:47 PM | #12 |
Yeah I am running the f-body pump with truck accessories.
03-23-2016, 06:02 PM | #13 |
Thanks for the replies it helps a lot
