03-22-2016, 06:59 PM | #1 |
Custom Truck Lover!
What size 17 inch tire to use
I am using 17inch FJ steel wheels on my 64. I have a 4/5 static drop. What size tires are you guys running on your 17's? I have read 245/45/17 but I would like more input.
Squarebody guy |
03-22-2016, 09:18 PM | #2 |
Re: What size 17 inch tire to use
I was doing research on this myself a few months back. I currently run 235-75-15 tires, and was going to go to a 235-65-17 since they are almost the same height.
Not sure if that helps or not. But either way, please post pics once you have those wheels on. I am seriously considering the same wheels!
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE |
03-22-2016, 11:13 PM | #3 |
Custom Truck Lover!
I need more help.
The tires I have now are 205/70/15 and I want to get a tire for my 17s that will fill the wheel well. I am not going to bigger wheels. When I do a tire size comparison with a 245/45/17 it is smaller.
Squarebody guy |
03-23-2016, 02:52 AM | #4 |
Those wheels look pretty narrow. They look to be around 6" wide. The widest tires that will look right on those would be a 225, possibly a 235. Personally I think these trucks look good with a 28" tire so that would be a 60 series in those sizes (225/60/17 = 27.6" diameter, 235/60/17 = 28.1").
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
03-23-2016, 06:36 AM | #5 |
I am with Rick on this one to fill the wheel well nicely a 28" tire work well. That is what I am running but on 15" wheels. I think those wheels are 7.5" wide with 4 1/2" of back spacing. You may be able to get away with the 245 on the rear but the front may have issues in the front with your drop. It may fit OK or be close it is hard to tell. You could get your rear set mounted and bolt them on the front and see how it fits and if your good get the second set.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-23-2016, 08:52 AM | #6 |
Custom Truck Lover!
The wheels are listed at 7.5 inches but I measured at 8.5 from lip to lip. I like the idea of a taller tire 28 or 29 inches. I am thinking 255/60/17 (29) or 255/55/17 (28). Ill post pictures after I do it. I will buy tires in the next week.
Squarebody guy |
03-23-2016, 10:30 AM | #7 |
Never Ending Projects
On my 17x8 wheels, I used a 235/60-17 tire, which comes out about 28".
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
03-23-2016, 10:56 AM | #8 |
Custom Truck Lover!
That looks perfect. Great color too!
Squarebody guy |
03-23-2016, 11:16 AM | #9 |
Did you measure inside or outside? Inside at the bead is where you need to measure.
Jimmy
03-24-2016, 12:47 PM | #10 |
FWIW, I went on the recommendation of 245/45r-17 for tires and I'm severely disappointed. They look too small for the size of the truck. Like those 235/60's. About perfect.
03-24-2016, 01:33 PM | #11 | |
Custom Truck Lover!
Squarebody guy |
03-24-2016, 12:56 PM | #12 |
Also, I should add I'm using the FJ rims with a 4/6" drop.
03-24-2016, 06:13 PM | #13 |
Cool, looks good.
03-24-2016, 08:14 PM | #14 |
Custom Truck Lover!
Bolted them on. The bed is just sitting there and not bolted on. I have to make a new cross member to go around the gas tank.
Squarebody guy |
03-28-2016, 09:04 AM | #15 |
You said you had a 4/5 drop, the pictures look stock height. I found these caps while looking for the wheels you have on ebayy and thought they might look cool with a Chevy logo panted in the middle. They kinda have that old artillery look to them.
03-28-2016, 11:27 AM | #16 |
Custom Truck Lover!
Those do look nice. I may just stay black or add a Chevy center cap later.
Squarebody guy |
