Old 03-23-2016, 05:58 PM   #1
Bart Savage
Bart Savage's Avatar
E-brake
Looking to remove the emergency brake cable from the frame...any ideas on how to remove it from where it goes through the frame after it drops down from the firewall?
Bart Savage is offline   Reply With Quote
Old 03-23-2016, 06:18 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: E-brake
I have used a zip tie to compress the little metal fingers and pull it through the hole. Once the little fingers get past the frame, you can pull it so the zip tie slides down or cut the zip tie off.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-24-2016, 09:11 AM   #3
Lugnutz65
Lugnutz65's Avatar
Re: E-brake
Also a small size hose clamp works. See THIS LINK from my BLOG Tips and Tricks Section where I do the same thing for the rear wheel backing plate.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 03-25-2016, 02:38 AM   #4
Bart Savage
Re: E-brake
Even better!! Thanks!
Old 03-27-2016, 11:42 PM   #5
Bart Savage
Re: E-brake
hose clamp trick worked like a champ!! thanks lugnutz65
Old 03-23-2016, 10:58 PM   #6
Bart Savage
Re: E-brake
Great idea!!! Will give it a shot!
Old 03-28-2016, 08:24 AM   #7
patrickk1
Re: E-brake
On other vehicles, I've always just found a socket that will slip over the metal fingers to compress them. Only takes a couple of seconds.
- Patrick
1964 GMC pickup lwb ~ My newest build!
1937 Ford Coupe ~ Custom frame, LS1, quickchange
1950 Chevrolet 3100 ~ Bagged (Sold)
1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car)
1967 Chevelle ~ 454 Triple Black (Sold)
1964 Chevrolet Impala SS (Sold)
patrickk1 is offline   Reply With Quote
