brake bleeder problem on 66'
Bleeding my brakes on the 66' (drums) . Rears done, moved to fronts, here's the problem. The bleeder screw is so close to the spindle C that you can not get a wrench on it. The wheel cylinders are NAPA brand, bleeders are metric (10 MM imagine that) Has anybody ran into this problem ?
If you don't like this ![]() |
![]() ![]() Join Date: Apr 2012
Re: brake bleeder problem on 66'
Have you tried taking your old bleeder and putting it in the new cylinder ? I've done that before and it worked
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
unfortunatly I don't have those any more. Do they make extra long bleeders ? I looked at NAPA's web site, but couldn't really tell if their is a differance in length.
I have had this problem before. I was able to use a 1/4" drive 10mm metric deep socket.
![]() Join Date: Mar 2014
Same problem here and I didn't want to re-use my old rusty ones. Searched all the parts stores and the only one who had any was O Reilly's. H9401-2, pack of two for $3.59. They are identical to originals, about 1 1/2" overall length.
Worked great using a 10mm brake bleeder wrench! |
Thanks Rolland - now if I can get mine out without taking everything apart. But it looks like the right side has a little more room than the left.
#7 | |
