Old 03-24-2016, 07:25 PM   #1
In The Ten Ring
Has anyone disassembled their heater box?
Hey you guys. It's about time to start back on the truck, hopefully this spring will see me getting her back together.
The flapper in my heater box is rusted on both sides, the thing is held in there via a rivet, has anyone drilled that rivet out in order to clean up the flapper?
If I decided to do that, could the rivet be replaced with a bolt of some kind?
In The Ten Ring is offline   Reply With Quote
Old 03-25-2016, 12:17 AM   #2
In The Ten Ring
Re: Has anyone disassembled their heater box?
ttt
Old 03-25-2016, 01:17 AM   #3
Ontcalimo
I tried doing that but end up purchasing a new one.
Ontcalimo is offline   Reply With Quote
Old 03-25-2016, 08:14 PM   #4
gainew
Did you replace the flappers (doors), or did you replace the whole heater box? Where did you get them? The doors in mine, I have factory air, are rusted and don't work. Thanks,Gaine
gainew is offline   Reply With Quote
Old 03-25-2016, 09:58 PM   #5
Troynutts
Troynutts's Avatar
70 c10 (heater in off position fans not running)
It feels like the heater is always on, I can feel a lot of heat from the dash and I'm sure the truck isn't over heating Any ideas?
Troynutts is offline   Reply With Quote
Old 03-27-2016, 03:32 AM   #6
F.A.A.benny
Could you post a pic of the flapper doors you are referring to? On a factory ac truck, the heater box has no flappers
F.A.A.benny is offline   Reply With Quote
Old 03-25-2016, 03:42 AM   #7
F.A.A.benny
why not just replace with another rivet instead of using a bolt?
Old 03-25-2016, 11:47 AM   #8
kehstr
kehstr's Avatar
subscribed
kehstr is offline   Reply With Quote
Old 03-25-2016, 04:55 PM   #9
In The Ten Ring
That's a great idea but I'm not so familiar with rivets. I have a rivet tool but little experience doing riveting.
I guess since no one else has done it, I may have to lead the way!
Old 03-27-2016, 01:18 PM   #10
In The Ten Ring
My flapper is inside of the rusted "backing plate".
Sorry, having problems with my camera and cannot get an interior pic.
Old 03-27-2016, 02:24 PM   #11
F.A.A.benny
You can remove that backing plate by drilling out the rivets. Here are a couple of pics of one removed and then reinstalled with new rivets
Old 03-27-2016, 03:31 PM   #12
In The Ten Ring
Oh yes, I already have mine taken apart and that piece derusted and repainted, but what I need to know is, did anyone take their flapper out?
Mine is held in place by a rivet at the bottom......did you take that out to derust it? My flapper is rusty on both sides and I'd like to repaint it.
*Your's looks nice by the way. What size and type of rivets did you put that back with?
**Is that an aluminum heater core? If so, where did you get yours?
Old 03-27-2016, 04:05 PM   #13
In The Ten Ring
OMgosh! I had the pictures after all! My camera isn't working right, but it works well enough I guess.
Here is the flapper I want to remove. Has anyone removed this so it can be painted on both sides?
Old 03-27-2016, 05:41 PM   #14
F.A.A.benny
the flapper door is held by the rod, not by a rivet. I cant remember what size they are off the top of my head. would have to check. The core is aluminum and it came from the local atuo parts store advance auto. all the big auto parts stores have them. Would just order through their website and check which local store has it in stock. The flapper do was painted on both sides
Old 03-27-2016, 09:55 PM   #15
In The Ten Ring
The flapper on mine is held by a rivet. Now it turns on a rod, but the rod is attached to a pivot and that is held by a rivet.
I do not have a pic and cannot get one for a few days a least.
Old 03-28-2016, 03:16 AM   #16
F.A.A.benny
If you drill out that rivet, the pivot will simply come off, leaving behind the rod. The rod will not come off if you remove that rivet. The rod goes through the bottom of the heater box, going through the slots of the flapper and finally exiting out the top of the heater box.. Look at it a little closer. You'll see what I'm talking about.
Old 03-28-2016, 03:21 AM   #17
F.A.A.benny
ok now after reading your post again, I think I see what the issue is. I believe that you assume that if you remove the rivet and the pivot, that the rod will just slide right out. Well that is more than likely not going to happen. That rod goes through the slots of the flapper with pretty much a pressed fit, meaning its not just going to slide out.
Old 03-28-2016, 08:26 PM   #18
In The Ten Ring
Really? My heater box is out in the garage right now and I'm too lazy to go back out there. If you are correct, it sucks!
I'd really like to paint the inner side of my flapper, what do you suggest?
Old 05-09-2016, 01:00 AM   #19
In The Ten Ring
ttt!
Does anyone know how I can remove the flapper from my (non) AC heater box so I can derust it?
How does this go back together?
Old 03-28-2016, 01:02 AM   #20
OregonNed
OregonNed's Avatar
This one is in mine, and it fits perfect. Amazon.com: Spectra Premium 94559 Heater Core:... Amazon.com: Spectra Premium 94559 Heater Core:...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
