Vortec head question
I'm going to install vortec heads on a 400 for my project stepside. I have been trying to gather all the info I need now, so there is no surprises when I wrap this thing up. The heads are at the machine shop getting steam holes drilled, and measured for retainer to seal clearance. I bought a vortec intake, and self alining rocker arms. What I'm not sure about is the coolant bypass. The truck will have the heater core hooked up, and there will be no valve in the heater hoses. Is that good enough, or do I also need to run a short hose from the intake to the water pump?
#2 | |
Re: Vortec head question
With that said, you need to address the lack of clearance between the guides and the bottom of the retainers. And fi d a deep dish piston if you want to run pump gas because a 64cc head on a 400 block builds some compression.
Anthony |
The block is a stock bore 400, with the stock dish pistons, I'm pretty sure the cr will be ok. The cam has .466 lift, and the machine shop is installing new springs, and measuring the retainer to seal clearance.
Stock dish pistons may not be deep enough. You need to measure. Guessing is not the correct way to do any engine. If its worth doing, its worth doing right.
Anthony |
I bought the block and heads from the same shop, he told me the compression ratio will be 9.2 to 1. I will make sure he measured, and not just guessing. Thanks for your input, is there anything else I need to double check? I want this done right, as I already blew the budget for the motor part of this project.
driving is in my blood
No need to measure things about. You've got stock pistons, a known value. Your putting on vortecs with 64cc chambers, another known value. What checking is needed? Its not like your running on the ragged edge of octane tolerance.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
#7 | |
Using 12.5 cc`s which is what the speed Pro replacement pistons are I come up with 10:1 compression. OP mentioned a .466 lift camshaft so I`m guessing short duration as well. Mix that with 10:1 compression with iron heads and you are looking at cylinder pressures much higher than stock and will create serious issues trying to run on pump gas. Pretty bad advice you are giving out Tom. Info like that can cause a guy to ruin his engine. Just because you give the answer that the OP wants to hear doesnt make it the right answer.
Anthony |
Ask the guy what the dish volume is for the pistons in the short block, better yet, ask him the particular brand and part #.
Most of those Vortec heads I have CC'd actually measure closer to 62cc's than the advertised 64. You have to be careful here, I would want a 22cc dish piston and somewhere in the .038-.044 piston to head clearance including gasket. |
Is this an aftermarket block or an OEM block? Very hard to believe you found a OEM 400 block that has a standard 4.125 bore still within spec after at least 35 years since being produced.
#10 | |
![]() Join Date: Jul 2000
Man, I wish I would have made notes on this when I built a 355 last year using a 1997 block and 062 heads, but I believe neither Vortec heads nor 96-up 5.7L blocks have bypass holes. But if your heater does not use a coolant valve, then you're good to go.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 03-28-2016 at 06:41 PM. |
Thanks Mike, that's what I needed to know.
I will measure the pistons, the engine is from a 78 k10, if nothing was changed it should have 19.5cc dish pistons. I will measure to make sure. The cam specs,Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,600-5,200 Intake Duration at 050 inch Lift: 214 Exhaust Duration at 050 inch Lift: 224 Duration at 050 inch Lift: 214 int./224 exh. Advertised Intake Duration: 288 Advertised Exhaust Duration: 298 Advertised Duration: 288 int./298 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.444 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.466 in. Valve Lift with Factory Rocker Arm Ratio: 0.444 int./0.466 exh. Lobe Separation (degrees): 112 |
It is a stock bottom end, there was no ridge at all in the bores. It's going back together with the stock pistons. When I get home, I will measure the piston cc, plexiglass sealed up, and a medicine dropper should get me close, right?
Assembled in the block? Not really, the pistons will be below the deck and if you measure off the deck surface, your numbers will be exaggerated.
#15 |
If the pistons are without a doubt the pistons that came in that block as installed from the factory, or ones with the same dish volume as the originals, you should be fine.
Those engines were somewhere in the low 8's CR with the factory 76cc heads. With no other changes, swapping to a 64cc chamber head should put you somewhere in the low 9's. |
#16 |
The block is bare. It was cooked, then new cam Bearings and plugs installed. The pistons are cleaned up and ready for new rings. I thought if I sealed up the dish of the piston with a piece of plexiglass, with grease, then used a cc dropper and filled up the dish???
#17 |
I used the better of 2 400 blocks, both were factory original, and they both had the same pistons. Do the specs of my cam look ok?
#18 |
Had the wife run out and snap a pic of the pistons.
#19 |
Depends on what you want to do. That's an old school grind that is a step or two above a RV cam for a 350. The 400 will swallow it up and I consider it an RV style cam for those cubic inches. It will do fine in your truck for daily usage, good manners, and gobs of low-mid range torque. |
#20 |
They appear to have a fairly large(safe) dish volume. No way to know the exact figure unless you measure.
Just looking at them, I see no problem with too high of a CR. |
#21 |
Thanks guys, all I am after is just a little more snort than stock. I bought the standard edelbrock performer vortec intake, a 1406 carb, and some standard ceramic coated long tube headers, and a rebuilt th350, with a little shift kit, and a 2000 stall. The truck has 342 gears in it. It sure seems like kind of a hassle to put these vortec heads on, but it should run good.(I hope!)
