03-31-2016, 08:03 PM | #1 |
What Engine do i have
/Users/Genaro/Desktop/IMG_5943.JPG/Users/Genaro/Desktop/IMG_5944.JPG
03-31-2016, 08:08 PM | #2 |
Re: What Engine do i have
your pics did not show up,try to load one at a time
03-31-2016, 08:39 PM | #3 |
Hmmmmmmmm hard to tell
1972 C10 - It might be old, but it's not slow |
03-31-2016, 09:33 PM | #4 |
Judging from this post I'd say a greasy one
03-31-2016, 09:40 PM | #5 |
LOL sorry ok will do
03-31-2016, 09:43 PM | #6 |
You have a small block chevy
Gotta get numbers! Don't once things are changed around it's usually impossible to tell without seeing numbers. Check the deck of the block, which is right in front of the pass. Side head. or on the bell housing! Post pics of those numbers!
1967 Chevy CST 10 1969 Chevy C/20 Longhorn 1969 K10 Suburban 1972 Chevy Cheyenne Super 10 turned K30 (sold) |
04-01-2016, 12:44 AM | #7 |
casting number is 3932388
04-01-2016, 12:56 AM | #8 |
Based on that, the block is a 68-79 GM 350 with a 4-bolt main. The stamps on the right hand deck might give a little more info, you might have to pull the alternator out to read the stampings properly.
1996 Chevrolet K1500 (daily runner) 1969 Chevrolet Suburban K20 "Solomon Grundy" *Click for build thread!* |
04-02-2016, 01:51 PM | #9 |
Go to nastyz28.com and you can decipher each part number and all that! Great site if you like to know about the numbers!
04-13-2016, 02:25 AM | #10 |
Thanks guys for the info.
04-13-2016, 09:30 AM | #11 |
Small block Chevy with HEI distributor, sitting on six cylinder mounts, with the newer style long water pump front accessory setup.
04-13-2016, 10:51 AM | #12 |
Rubber hoses with a glass body filter resting on top of the exhaust manifold ... what you have
there is a fire hazard. And yeah. 1968-79 350. Could be two or four bolt main. Only way to be sure is pull the pan & look.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
Tags |
engine, engine type, motor info |
