View Poll Results: dash choices original or new | |||
Original |
30 | 76.92% |
NEW please show me your idea |
9 | 23.08% |
Voters: 39. You may not vote on this poll |
Many of you have come to this problem. And I cant make up my mind. so you get a chance to help me with my truck.
1. Keep original dash instrument cluster shown below. 2. get a new instrument panel now I will show you the one I want after I get a polling done. but use yer imagination, there are a ton out there. and if you want show me you favorite one. GO!! ![]()
1960 SWB “Pops” If you won't support our troops then stand in front of them! |
Enjoy your truck
Re: you decide please
Do away with the one you show (idiot lights) and get an original factory gauges/tach dash.
Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
What Greg63 said. Preserve the past it never goes out of style.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
x2 |
![]() Join Date: Mar 2013
I can't vote because I have No idea what the rest of your truck looks like. lol My truck is gonna have a Fairly stock appearance, but alot of unique things added. I've decided to go with this style cluster as it best suits my taste.
http://i.ebayimg.com/images/g/vtYAAO...nZ/s-l1600.jpg
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
It's Better With Nitro
If you're willing to do the fabrication, wiring, etc., then you can modify the original. Otherwise, going with a modern version from Dakota Digital, and others would be my vote.
Back when I modified mine, there wasn't much in the way of options. Here is what I did with my instrument cluster, using left over gauges, scrap Lexan for a lens, sheet aluminum, and tasking my friend who runs a vinyl lettering and sign business to cut out the numbers and hash marks for me in reverse. ![]()
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
modified original like this?????
your the one that has to live with it. Aerotruk has the original flavour which looks good and is functional. after that spent money to your hearts content
ron |
![]() Join Date: Jun 2006
The Aerotruk deluxe dash is fine in fact it preserves the truck. But it depends on what your goals are, do you need the gauges to be spot on if your running more than a stock engine? Do you want a modern engine with gauges to match?
Link to performance style: http://www.boeseengineering.com/Shop...o-meter-gauges Link to modern style: http://www.dakotadigital.com/index.c...rod/prd774.htm
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
if it works or needs minor fix then keep it.
Never Ending Projects
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Vin63 wow I like it
You were able to preserve some of the uniqueness of an original yet modernize it for your application. I like that.
#15 |
Moderator
![]() ![]() Join Date: Aug 2011
Here is a thread with a really nice gauge panel: http://67-72chevytrucks.com/vboard/s...d.php?t=604093
Also see post 11 in that thread.
#16 |
What Greg63 said.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
#17 |
Thank you for the help everyone I have decided to save the cash and go with the older cooler one I have. I don't have the gauges that sucks but I don't have a super built motor and I will be adding gauges on a separate mounting. I'm thinking about making a console and adding gauges to it. I will post in my build thread the results on that mod.
