inline 250 with 373 posi???
so i have a 1969 c10 dont know what gears are in it now but when i go up hils i get honked at in the slow lane. my truck has a t5 tranny 235/75r15 not once have i been able to use my fifth gear. i dont even care about that fifth gear i just want to be able to have a little fun in my truck. use the fast lane to go up some hills and honk at other people. lay a patch if thats possible???? 250 inline 2barrel carb long tube headers, so duel exhaust. i was told to put a set of 373 gears in.. i found a 373 posi is that the way i want to go ? or what do i need to do here? thanx for the help yet again. was trying to find a video on youknowwhattube but i couldnt...
![]() Join Date: Oct 2011
If your truck came from the factory with a 6 cylinder engine (check the spid)....
then you already have the 3:73 diff. If your truck had come with a V-8 then your truck came from the factory with a 3:07 diff. All Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Re: inline 250 with 373 posi???
ok i did swap the rear out for a five bolt i forgot. the stock was 6 bolt. i cant open the case and look its my daily and i dont have time if im not swapping it. ill try and spint the tire trick to check it.. but would 373 posi be what i want?
#4 | |
Gear ratio won't help you |
![]() Join Date: Dec 2013
[QUOTE=Mrturner1;7545379]Sounds like you need a SBC to me. Inline 6 is a great motor, and they make a nice little torquey trail motor for 4x4 in my opinion. Some guys even get a bunch of horsepower out of them. But if you want something to just drop in as is and spin the tires/do 70mph in the fast lane, then look for a 350
Oh my God ! Are you kidding me ? I'll smoke your 350 all day long with a 292 ! Let's say for titles ? And that "little" 292 will still have the torque to pull the trailer with your truck on on it all the way back to good ol Tn , AHHH , Grasshopper you've built 1 Well 1/2 of 1 Engine let's not get all that and the box of chicken just yet ! "gear ratio won't help you " WHAT ? Hahaha ! Posted via Mobile Device Last edited by Grumpy old man; 04-02-2016 at 04:13 PM. |
im not looking to drop a 350 into it. or a big block. lol but thanx for the idea.. i have lots of cars with small blocks. i want this 250.
![]() Join Date: Feb 2002
I have a '68 C/10 Stepside, 292 L6, SM465, 12-Bolt Corp 3.73 Posi, 235/85/R16LT. Runs good and eats up hills. [The Posi I swapped out from a junkyard '69 GMC, back in the early '80s when the picking was good.]
I don't get why you're having a problem. What CFM carb is your 2-bbl? Stock, or aftermarket intake? Do you have a crossover pipe on your dual exhaust? Engine stock or modified? Points or HEI? If you have an overdrive transmission, you should be able to use it.
#8 | ||
"I ain't nobody, dork."
GOM... nailed it again.
![]() Gary
Good grief I said they are great motors! lol I was complementing them, even said some guys (like you apparently) get tons of horsepower out of them. Let's not start taking low blows about my build. I was giving him a quick solution, doesn't sound like he wants to sink a bunch of money into it, and he mentioned swapping rear ends as a possibility. To me, that sounds like he's looking for a quick fix, which a small block would be. Changing gear ratio doesn't make a slow truck fast
![]() I'll leave the one about racing alone lol..... K&N filter and 44 psi in the tires should do the trick lol Last edited by Mrturner1; 04-02-2016 at 04:59 PM. |
#12 | |
![]() Join Date: Jan 2002
To me it sounds like you have 3.07 gears if you can't even use 5th. Did you find an entire rear-end with 3.73 gears or just the carrier and posi? I would say 3.73 or even 4.10 gears since you have overdrive. What gear are you trying to climb hills in?
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Put the 3.73 posi in and you'll be happy ,
Mrturner1 , A little good natured ribbing is all in fun . While your sitting at the line smoking your tires with that one wheel wonder a "little" 292 with a manual Trans and 3.73 posi will sit and git ! There were lots of 350 guys back in the early 70's who lost their shirts betting against the "little" l6 engines . It's all about correct balance and weight distribution and a taller gear just makes them quicker down the road . Learn to love the color of fading tailights ! Hahaha ! What will 44 psi in the tires do ? Help it spin faster ? Try 16 psi maybe it will hook up a little better , or rip out your driveshaft ! Posted via Mobile Device Last edited by Grumpy old man; 04-02-2016 at 06:24 PM. |
#15 | |
I still don't think gears makes a slow truck fast though ![]() My hat is off, and I am truly amazed and interested in learning more if I6's are beating SBC's at the strip ![]() |
#16 | |
#17 |
My truck came with a 250 and a 4.11 rear end.
I have been considering a 3.73 so I could go a bit faster but still climb WV hills. |
#18 |
OP sorry we hijacked you, just having some fun
#19 |
i need gears i know it. ok . so i do have HEI my exhaust has no H pipe. my 2bb i dont know the cfm its some carb i dont even know ill get a pic of what the last guy did. stock intake. ok so i tryed to do the jack up and mark the tire and axle then spin count and i was sloppy at it i was in a rush and ill do it right if this isnt close to gear ratio. because i dont know what they all are or what are good for what tire 10 turns. shaft 15 . so from what i saw its 1.5 but like i say i was sloopy is that right or close to anything? after looking more i guess it being a 12 bolt makes a dif as well does anyone know what i have from this ****y post??
#20 |
Ok , you don't have a 1.5 rear so try that again and this time rotate the passengers side rear tire .if you have access to a 3.73 TRUCK 12 bolt posi BUY IT ! They are hard to find A car 12 bolt will not work . If your not sure take a picture and the guys in here will tell you what it is . Post some pictures of the truck and engine . What size tires are on it ?
Posted via Mobile Device |
#21 | |
A picture would help. Here's a driver side pic of my 292: Offenhauser intake, Edelbrock 1404 -500 CFM 4 Bbl carb, Clifford headers. A note about the crossover pipe. It may be urban hotrodder legend, but crossover exhaust is supposed to help out with scavenging and improve low-end torque. [What you want when climbing hills and pulling loads.] The guy who did mine, an old midget-racing pit guy, told me that. He also calculated that since the collectors were asymetrical on the L6 -- with 1-2-3 in front of 4-5-6 -- that an angled cross tube would be better than an "H" pipe. So mine looks more like an "N". Another side effect is that as the pulses from the front cylinder pop, they are countered by the pulses from the rear cylinders and this cancels out their being heard at full volume by human ears. Some voodoo, I know, but it works. I've been running the crossover for about 30 years, and I could feel it from day one.
#22 |
Ok so this time I think I have it 37 and 10 so 3.7.....is that 3.7.3s lol?
#23 |
#24 |
I have a 70 short step, stock 250 with a 3 in the tree no overdrive. I push cars up over hills if I had more pedal I would pass them and this is at 60/70 mph
#25 |
i have the same headers as you. in the pic as far as my 2bbr its not stock and my phone wont let me load it . it is the stock manifold and the PO made a sort of Y shape for a 2-1 adapter.
