Old 04-03-2016, 10:05 PM   #1
Clavo106
Two Q's tailgate gap & roll pan
Need to know does the tail light"tailgate gap at top to bottom get narrower. Taper down? And do I need to cut the bottom part of the bed to get the roll pan to fit? In pic..any help would be nice thanks..
Clavo106 is offline   Reply With Quote
Old 04-03-2016, 10:18 PM   #2
Robznob11
Robznob11's Avatar
Re: Two Q's tailgate gap & roll pan
I'm trying to remember what I had to do to get mine on. I think I may have had to cut a rectangular portion out so the license box would fit. But other than that just line up the body lines and screw it across the top. Then weld up the ends...I don't think there is any taper.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 04-04-2016, 07:47 AM   #3
chiefcfd
chiefcfd's Avatar
My roll pan installed without modification. I used screws to hold the top under the tailgate. Then made brackets to mount to the bedside at the bottom. I did not weld mine, I continued with the gap. Looks like your bedsides are pushed out at the top. Use a ratchet strap to pull them back in place.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 04-04-2016, 12:54 PM   #4
Clavo106
Ya. I believe I need to cut the section out because the license plate box doesn't fit.. that one down. Thanks! But the gap without tailgate 67 1/2 lip to lip and 67" bottom lip to lip and my roll pan is 67" very tite fit at the bottom corners. Ill try the strap good idea but would i be better moving the bottom out.. d oues only have a quick measure ment. I have two beds without original tail gates and I putting on used bed skin so look to do this right.. thanks!
Old 04-04-2016, 09:52 PM   #5
swamp rat
swamp rat's Avatar
If the bedsides were ever removed and reinstalled then someone had to cut the welds to do it, the welds are at the bottom of the rear stake pocket. There are also bolts on the underside of the bed sides, kinda hard to find them but they are there. I would loosen them up before you try to pull the sides back in..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
