Old 04-04-2016, 12:29 PM   #1
eighteenninetytwo
NP 205 Mount
I was reading through one of the associated forums here (early burbs I think) and there was a sinificant thread regarding the history of attaching NP205 TC's to the frame and why it was a very bad thing to do and would likely cause stress and crackign to the TC. Mine is bolted to the frame, but my 75 is honestly a mall crawler with some sand thrown in twice a year. Is this a big issue and something I should remedy on a blazer?
eighteenninetytwo is offline   Reply With Quote
Old 04-04-2016, 03:55 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: NP 205 Mount
I don't think so. Well, I'll qualify that and put it this way: If there is I've never heard of it. When you say frame mount though, I'm thinking attached to frame-mounted cross member. But now I'm wondering if not that, what else is there? IDK, now I'm lost!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-04-2016, 09:23 PM   #3
eighteenninetytwo
Re: NP 205 Mount
Mine (IIRC as its in shop) has a bolted attachment to the frame itself on the side of it.. trying to find a picture now actually.
Old 04-05-2016, 09:00 AM   #4
lane224
lane224's Avatar
Re: NP 205 Mount
My 73 all original. 203 t-case bolted to frame. not sure if this helps.
lane224 is offline   Reply With Quote
Old 04-05-2016, 10:34 AM   #5
68Timber
68Timber's Avatar
Re: NP 205 Mount
It helps me, I've never seen a side mount like that. Wonder what year was the last for that type mount? Is it just one side?
eighteenninetytwo I wouldn't sweat it. If you were going to make a trail rig out of it then maybe.
John
74 Honda Z50 build
Old 04-05-2016, 11:04 AM   #6
CrewCab59
CrewCab59's Avatar
Re: NP 205 Mount
The np205 used the side mount 1969-1974 ish ,might have been until 73. The side mount was just extra support. The support torque rod were used in later years.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 04-05-2016, 11:54 AM   #7
lane224
lane224's Avatar
Re: NP 205 Mount
Yes Passenger side. First one I've had like that. Kind of stumped me when I was doing the lift. Was thinking about removing it and finding a torque rod for it.
Old 04-05-2016, 12:01 PM   #8
eighteenninetytwo
Re: NP 205 Mount
The convo on the other forum was centered around the use of the torque rod as opposed to the bolt to the frame. Opinion from an ex GM worker was that the frame mount was insufficiently flexible under power and caused cracking. That was why they switched to the rod system after 74. I have a 1972 NP 205 so its mounted direct.
Old 04-05-2016, 12:10 PM   #9
lane224
lane224's Avatar
Re: NP 205 Mount
I have a 71 Blazer with 205. Does not have either torque bar or bracket on it.
Just sits on cross member. Didn't think the 205s used the extra bracket/bar on the first Gens.
Old 04-05-2016, 07:10 PM   #10
CrewCab59
CrewCab59's Avatar
Re: NP 205 Mount
Yes all 69-72 Np205 had the side mount . If the pad on the T-case isn't drill & taped is a later model Np205 .
1971 Chevy C/10
Old 04-05-2016, 07:34 PM   #11
lane224
lane224's Avatar
Re: NP 205 Mount
Thanks for the info.
