04-04-2016, 09:47 PM | #1 |
Is this a 63 rear diff?
Want to make sure this is a 63C 10 rear differential before I have a rebuilt. Can anyone verify this for me?
04-04-2016, 10:01 PM | #2 |
Check The Champ, Demonstrator
Re: Is this a 63 rear diff?
Are the backing plates pressed on or bolted on would be the first indicator.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
04-04-2016, 10:15 PM | #3 |
Built in Warren Michigan in 1963 or 64. WE code is a 3.73 ratio positraction.
04-04-2016, 10:16 PM | #4 |
WE code states 127" wheelbase.
04-04-2016, 10:18 PM | #5 |
How they'd do the overhaul, watch the video.
https://www.youtube.com/watch?v=miCa9cDNKgI
04-05-2016, 08:58 AM | #6 |
Backing plates are pressed on.
Thanks so much for the help guys! A local shop will rebuild totally with 5 lug 30 spline axles, 3:42 gears, Eaton posi, new bearings, new yoke, for ~$1500. |
04-06-2016, 06:13 AM | #7 | |
Would a normal Eaton Posi hold up in my truck? Are there different/stronger Posies a ailble for our 60's trucks? |
04-07-2016, 12:55 AM | #8 |
60-66 Nut
The '63-'82 truck 12 bolt housings are all basically the same. The differences with the '63 12 bolt is 1) The pressed on backing plates and 2) The 17 spline axles 3) A different wheel/axle bearing and seal. As far as the carrier is concerned, any truck 12 bolt carrier will fit a '63 truck 12 bolt housing.
04-05-2016, 05:32 PM | #9 |
It already has the posi !
Living The Canadian Dream in British Columbia |
04-05-2016, 08:37 PM | #10 |
04-06-2016, 12:01 AM | #11 |
60-66 Nut
If it is still inside after 53 years, then it will be a 17 spline posi. Depending on which posi unit it is, the spider gears may or may not be available. Plus the fact that it will likely need rebuilt. The cost of rebuilding a posi is nearly as much as buying a new unit.
