Old 04-06-2016, 11:51 AM   #1
65chevysub
65chevysub's Avatar
Sub died in middle of the road this morning
Just had my carb rebuilt and new filter installed and was running fine for 3 days. Started out this morning and it died, so I pushed it while wife steered. Pulled the filter and pump is working fine. I have the Ignitor kit in distributor so no points/condensor. Cranks fine. Called the guy who worked on it and he towed it to his shop but thought I would see what members here think might be wrong. I'm leaning toward something stuck in carb that got through. I ran straight line to carb and still no start.
What do you all think it could be?
283, 4 bbl Carter. No problems until now except running rich and hesitation.
Thanks in advance
65chevysub is offline   Reply With Quote
Old 04-06-2016, 11:59 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Sub died in middle of the road this morning
Did the old resistor get removed from the distributor wiring? I would also test for a low voltage condition from your ignition switch...just in case.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-06-2016, 12:47 PM   #3
Brad54
Brad54's Avatar
An old guy once told me "90-percent of fuel problems are ignition."
I have yet to prove him wrong.
Check for spark.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 04-06-2016, 01:38 PM   #4
65chevysub
65chevysub's Avatar
I still have a resistor on the firewall. I'm leaning more towards electrical/spark the more I think of it.
Thanks guys. I'll post the problem here when I get my truck back.
Old 04-06-2016, 03:27 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
HEI's require a full 12 volts to operate correctly....any less and that'll burn them up in no time. Sounds like it has no sparkie....course the easiest way to check is put your tongue in one of the wires while the wife cranks the engine. HAHA!
Old 04-06-2016, 05:49 PM   #6
65chevysub
65chevysub's Avatar
TJ. I don't have an HEI setup on mine, only a regular distributor with the "Ignitor" kit in it. Anyways the problem was simple and an easy fix. One of the wires on my ballast resistor fell off. If I'd had a flashlight, I could have fixed it myself.
Thank you to everyone who replied and offered suggestions.
Old 04-06-2016, 08:53 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Glad it was a simple fix.
Old 04-06-2016, 08:59 PM   #8
Brad54
Brad54's Avatar
That old man is STILL batting 1000!
Glad you were able to solve it.
-Brad
Old 04-06-2016, 07:12 PM   #9
Glad it was an easy fix
