Old 04-08-2016, 09:18 AM   #1
72cs20
Replacing 62 rearend with a 72 rearend
Hello all,
I've got a line on a 72 C20 trailing arm rear axle with 4.11 gearing. I'm thinking this would be a good swap into my 62 C20.
Question - Can just the 3rd member be swapped or does the complete axle need to swapped ?
Thanks.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 04-08-2016, 09:42 AM   #2
Re: Replacing 62 rearend with a 72 rearend
There is differences in the splines between the early years and the 72. I just had a shop do a changeover for mine and found out about the spline count differences between the early years (pre 66 I believe) and the later 12 bolt.
It can be done, but it would be probably easier to do the entire axle. It will be a 1.5" wider axle overall, but will work.
Old 04-08-2016, 01:21 PM   #3
Shaky
Six in a row makes it go...
Shaky's Avatar
Is there a difference on the track bar? I have a '71 rear in my '66. My buddy says my truck is "crabbing". I haven't done any measuring yet, but I'm using the '66 track bar and wondering if I need an adjustable one.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 04-08-2016, 04:51 PM   #4
72cs20
Yes, I believe there are track bar mounting differences to take into account.
