Old 04-08-2016, 03:16 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Help with Spark Plug Choice
I am going to change the plugs in my bone stock all original 72 c10 with a 350 4bbl. and 87,000 miles. If I keep the truck 10 more years I may, at the most, put 10/15,000 miles on it over that time. Other than installing the Pertronix Distributor, ignition wires and one of their 40,00 volt coils I have waiting to be installed and maybe putting a dual snorkel air cleaner on the truck in the future the engine shall remain stock. My research has told me there are 4 different types of plugs, copper, platinum, double platinum and iridium. The prices vary from 1.89 for copper plug to 8.25 for the iridium. Can you guys/gals give me some real world info on what you are using for plugs. If my old memory is functioning correctly I believe that unlike todays vehicles the plugs in these engines form the 70's needed plug changes every 10,000 miles
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-08-2016, 04:00 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Help with Spark Plug Choice
Stock truck and having no issues I would stick with what's already in it.
R45TS plugs
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-08-2016, 04:08 PM   #3
Already Gone
R45TS plugs
Andy do you mean don't change them or replace them with what is already there.
Old 04-08-2016, 04:26 PM   #4
cdowns
cdowns's Avatar
i'd check them to see what the condition is first
Old 04-08-2016, 04:44 PM   #5
Andy4639
Old member
Andy4639's Avatar
I would pull them out and look at the burn on them. If they look good go with the same thing.
Back when I had the stock 307 I changed them every 15,000 but I would pull them and wire brush them good also if I thought I had a bad one.
Old 04-08-2016, 04:45 PM   #6
Sicklajoie
The Niner
Sicklajoie's Avatar
I go against the grain and have always run Autolite 24 Copper Core plugs.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 04-08-2016, 06:21 PM   #7
Already Gone
Its funny you mention the Autolite plugs. Not knowing what wa sin the truck and how long they'd been there I went and pulled the one closest to front on drivers side and her it is . Its an Autolite # 26 and looking at it I think the electrode looks like it should but I would guess it has been in there a long time.
Old 04-08-2016, 09:43 PM   #8
firedemon
I would go with the ac plugs and don't forget to open the gap for the electronic ign to .045 should get you 15 easy if everything else is good . back then tolerences and points weren't as good as they are now 100,000 was a worthless engine now its nothing that's why plugs had to be changed so often . I do still have a spark plug cleaner I use for points
firedemon is offline   Reply With Quote
