Old 04-10-2016, 12:30 AM   #1
lrmarquez80
ridetech c notches
I was wondering if anyone knew If I really need the c notch installed on my frame if I don't plan on slamming it. of course I'm lowering the truck a bit but not much. thanks
lrmarquez80 is offline   Reply With Quote
Old 04-10-2016, 03:30 AM   #2
'68 Newtricks
'68 Newtricks's Avatar
Re: ridetech c notches
If you don't plan on putting weight back there, you can get away with more drop. I'm at ~5 3/4" drop back there and bump off the C notch bumpstops when carrying weight. I've had up to 1080lbs in the back, that put me about 3/4" from the stops at rest.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 04-10-2016, 04:53 AM   #3
OARNGESI
OARNGESI's Avatar
It isn't needed but you'll probably ending up notching it to get lower. With your bags deflated it will be the equivalent of around a 8in drop
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-10-2016, 06:48 PM   #4
lrmarquez80
I wont be bagging it. I'm using coil over shocks. its the ridetech coil over kit level 2
Old 04-30-2016, 12:19 PM   #5
chase@ridetech
chase@ridetech's Avatar
I would use the supplied notches to get you the best ride quality and suspension travel. What amount of drop are you looking to get?
Chase Mundy
Direct Line: (812) 481-4736
Email: chase@ridetech.com
chase@ridetech is offline   Reply With Quote
Old 04-30-2016, 12:22 PM   #6
chase@ridetech
Here is a Picture with the level 2 coilovers installed. Are you looking for a stance similar to this? Also, It does not require any modifications to the bed floor.
Chase Mundy
Old 05-05-2016, 05:05 PM   #7
lrmarquez80
Thanks for everything bud. Kits looking great. I just lack the c notches. I'm going to install them anyway. The stance on the pic looks about right for me. Probably bigger wheels, but yeah. I'll send you some pics when it's done. Beyond impressed with your products.
Old 05-05-2016, 06:44 PM   #8
DBK81
DBK81's Avatar
Just curious, if doing coil over setup then why the want for performance robbing wheels? Pictured above are 18" and are by far the best performance option for a pro touring style ride.
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 06-01-2016, 12:01 AM   #9
chase@ridetech
It all depends on what you are after
whether you are running 15's, 18's, or 22's... going with a complete kit, you will end up with better handling and better ride quality. All in all its a win win
Chase Mundy
