Old 04-10-2016, 01:38 AM   #1
Adamcalnan
1978 k20 wiring nightmare
I have a 1978 Chevy k20. The wiring on my truck has been a nightmare. Now I have replaced the 2 relays under the dash and searched for hours. When. I turn either sides turn signals on all of my lights blink on the outside of the truck minus my headlights, including my cab lights. Any help would be greatly appreciated!
Adamcalnan is offline   Reply With Quote
Old 04-10-2016, 07:32 AM   #2
nsstring
Re: 1978 k20 wiring nightmare
Start by pulling all the turn signal bulbs and see if one of them is a single contact bulb. If so it connects across the park/tail light and will make them all blink.
nsstring is offline   Reply With Quote
Old 04-10-2016, 11:18 AM   #3
hatzie
Moderator
hatzie's Avatar
Grounds... Look at the radiator support grounds first.
Just because the black wire jacket looks good doesn't mean there's still copper inside the jacket...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-10-2016, 11:42 AM   #4
Pontiac1976
Pontiac1976's Avatar
"GROUNDS" Very true. Bad grounds will do all kind a stuff. They have you casing all kind a stuff. All start with the easy stuff go throw A-Z
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
