04-10-2016, 11:38 AM | #1 |
Fitting a new water pump and Timing cover -Shims??
Well, I hope the title was understandable.
I have bought a sexy new water pump for the 350 motor. I also bought a new chromed cast metal timing chain cover for it recently, to replace the pressed steel, rusted chrome one I removed. The new cover has been built in already. Seems the new cover is too thick. If you look at the photo below, you will see that with the one side pushed flush against the front of the block, the other end lifts away quite a bit from the block where the second waterway needs to meet it with a gasket. I looked at the old pump and cover and there is a mark where the impeller cover plate at the rear pushed against the old chrome plated cover. Note the light coming through. SOOOOO....... MY QUESTION IS THIS: If I had a pair of spacers or shims laser cut exactly like the gasket is patterned in 3mm mild steel or even stainless (not sure which is best option tbh) and then sandwiched it between two fibre gaskets, would this be a sensible and safe option? I copied the gasket like this. I am dropping the viscous fan and going with a pair of electric fans from a modern car on either a thermal switch or manual override, so the space lost toward the front should not be that critical. All advice appreciated. Thank you.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
04-10-2016, 12:09 PM | #2 |
Re: Fitting a new water pump and Timing cover -Shims??
Merely an observation. I would think that if you move your pump out by 3 mm, which I guess is about a 1/4", that your water pump, alternator and crank pulleys will be out of alignment now. It may not be super critical or even a problem once its all back together. Belt wear may be accelerated though.
As far as the fans, I like the old stock fan set up with the fan clutch. I have yet to come across an electric fan that can reliably cool a Big Block for every day use.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
04-10-2016, 12:47 PM | #3 |
04-10-2016, 12:48 PM | #4 |
Drove it daily last year (spring to fall)
04-10-2016, 01:04 PM | #5 |
Pretty clean set up there Tom. Ive tried the electrics several times. Towing in traffic is where I seem to have problems with them. The factory setup has just been way more reliable for me under the conditions that I encounter. I suppose if I wasn't towing and hauling, the electrics might work.
04-10-2016, 12:51 PM | #6 |
If you shim out the Water pump, You will have to shim the Crank pulley and the Power steering/Alternator out the same amount to fit it. I cannot see the pics here at work, is it possible to Clearnce the Aluminum Cover to fit behind the Pump?
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
04-10-2016, 01:08 PM | #7 |
Get a long water pump instead of the earlier short pump, and swap pulley and brackets to factory long water pump versions.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
04-10-2016, 01:16 PM | #8 |
A BIG X2 OR go back to stock timing cover ... Or as said above your belts wont line up ..... NOW you could play around with some pulleys and maybe be able to use a thicker shim/spacer and make it all work
04-10-2016, 01:11 PM | #9 |
I might add that the water pump pulley is the high flow option which I'm sure helps
04-10-2016, 02:03 PM | #10 |
I would bet those brackets aren't all that easy to come by over there.
04-10-2016, 03:32 PM | #11 | |||||
Thank you guys. It seems the solution is easy enough.... Looks like the simple solution is to remove the thick cast cover and replace it with the old Pressed steel one or at least another pressed steel unit. The pump I bought is exactly the same height/length as the one that was fitted before. It's the sexy cast cover that is the problem. PITA but it will be solved. Thanks for the help, feedback and advice.
