04-12-2016, 01:29 PM | #1 |
Tri four Link Which way is better
Tri four Link Which way is better ??
Having a cross member and connecting to that or have them connect to the side of the chassis? |
04-12-2016, 01:41 PM | #2 |
Re: Tri four Link Which way is better
I think the only real reason you see it like that in your picture is because of interference issues, such as with the gas tank.
I think most guys go to the chassis which eliminate the cross member. Either way, I think it's accomplishing the same thing. |
04-12-2016, 08:26 PM | #3 |
I'd have to agree with Hussey in that it is primarily builder's preference but I have no idea if one has an advantage over the other. I'd think most guys pretty well emulate what GM did with the Chevelle size cars for over 20 years and that's like your top drawing below the photo.
04-12-2016, 10:48 PM | #4 |
Thanks guys, helps me get an idea and good to know either way works.
04-13-2016, 10:29 AM | #5 |
I personally would be very skeptical of the pictured set up. I can't explain it in engineeringese but lots of strength is lost in having the mounting brackets that close together. The triangulation strength is somewhat proportional to the length of the sides and angles. Morrison won't sell their tri 4 link for a truck application. They say the frame rails are too close together for optimum strength.
04-14-2016, 05:14 PM | #6 |
there are a few good write ups on the geometry of a 4 link and how it works for traction and suspension. the angles pertain to centre of gravity and a whole bunch of other factors. an evening in front of the computer screen is well worth the time on this subject if you want it to work properly.
04-15-2016, 05:39 PM | #7 |
I've built a few 3 links and 4 links over the years. There isn't just one right way, but there are lots of wrong ways. Here is a good thread on pirate that will detail everything you ever wanted to know. Post 383 is the excel calculator created to let you run numbers to see what you anti squat, roll and other stats are based on your configuration. I have used these calculators for almost 10 years and have never been disappointed.
http://www.pirate4x4.com/forum/gener...204893?page=39
55.1 GMC Suburban Hydramatic |
04-15-2016, 07:47 PM | #8 |
that's what I was talking about. I looked at that site before but couldn't remember the name.
good luck. |
