04-12-2016, 08:40 PM | #1 |
Generator swap to internally regulated alternator
I am in the process of replacing the generator on my 62 with an alternator. I believe it's a Delco remy 10si. I have already figured out the mounting but my question is about the wiring. On all of the 10si wiring diagrams there is a diode wired in between the terminal #1 and the ignition switch. Do I need a diode or will the charging light in the gauge cluster work as one? Thanks. Here are some pics of the alternator mounting brackets
04-12-2016, 08:41 PM | #2 |
Re: Generator swap to internally regulated alternator
02
04-12-2016, 08:42 PM | #3 |
03
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
04-12-2016, 09:47 PM | #4 |
One foot in front of the other
I believe you will find alot of info in the FAQ section.
04-13-2016, 12:16 AM | #5 |
With a light you do NOT need the diode
04-13-2016, 12:20 AM | #6 |
60-66 Nut
Also lots of info in the Electrical section of this forum.
04-13-2016, 01:02 AM | #7 |
Yes the faq section has a very good write up on putting in a internally regulated alternator but there was nothing mentioned on diodes and it was being installed on a truck that came with an externally regulated alternator and mine has a generator so I wasn't sure.
04-13-2016, 01:03 AM | #8 |
Thank you! Exactly the answer I was looking for.
04-13-2016, 10:55 AM | #9 |
Never Ending Projects
With a dash light (not LED but actual incandescent bulb) there is enough resistance to prevent the alt from back feeding the ignition and keep the engine running when you turn off the key. If you do not have a dash light, then using a diode will prevent this.
I am currently using the diode method in two vehicles and it works great.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
04-13-2016, 11:05 AM | #10 | |
04-13-2016, 12:11 PM | #11 |
The "GEN" light in the dash comes on when "A" the engine is not running (but key on) or "B" no output from ALT (with engine running)
04-13-2016, 02:57 PM | #12 |
What jtrichard said ^^^^^^
04-13-2016, 03:19 PM | #13 |
Thank you guys this is exactly what I was looking for
