Old 04-15-2016, 09:35 PM   #1
ranger danger
ranger danger's Avatar
Dumb Question
Will headers help to reduce operating temp of the motor? My 454 sometimes gets a bit hot (225*) in stop and go traffic on 100 degree days. Id like to get control over that. I will be towing a 6000lb travel trailer in the mountains of northern California with it starting this summer.
1969 C20 Suburban "Rez Dog"
Rebuild America one testicle at a time.
US Army 1977-1979 12B Combat Engineer
US Navy 1979-1983 Gunners Mate Guns (GMG)
NRA Life Member
Unrestrained Children in back seats cause Accidents.
Unrestrained Accidents in back seats cause Children.
ranger danger is offline   Reply With Quote
Old 04-15-2016, 10:12 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Dumb Question
In the few cars I've had that I put headers on here in Texas where the temp can climb up to 110 in the summer, I don't remember it affecting the engine temp. If the the fan, water pump, hoses radiator cap and the engine are in good condition I would spend the money on a new high efficiency radiator rather than the headers. However, if you have the extra money try both. Wouldn't hurt.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 04-15-2016, 11:34 PM   #3
nonstop
Re: Dumb Question
Agreed with the aluminum rad. I have headers and the thing still heats up sometimes. Another issue is headers can increase underhood temps, negating benefits.
nonstop is offline   Reply With Quote
Old 04-16-2016, 10:53 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Dumb Question
Throw money at the cooling system instead of headers. If you're still using the stock 40 year old original radiator, it might need a new core or need to be rodded out. Or like mentioned above replace it with a stock replacement or an aluminum. Use a shroud if you don't have one.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-16-2016, 11:09 AM   #5
ranger danger
Re: Dumb Question
I have a shroud. The radiator was rodded out about 6 months ago. The guy said it was about 30% blocked before the repair. Factory original copper radiator. Carb is a quadrajet built by SMI. Vacuum gauge shows a rock steady needle at about 21" vacuum. Intake is Edlebrock performer. MSD pro billet dizzy. Timing is set static at about 14*, all in at about 28-30* around 2600rpm.
NRA Life Member
Old 04-16-2016, 11:21 AM   #6
'63GENIII
'63GENIII's Avatar
Re: Dumb Question
If the radiator is big (4 core) and clean, Id start looking at airflow and water circulation. My 396 used to get pretty hot while towing until I got rid of the flex fan. Installed a 19" or 21" (can't remember which) 7 blade steel fan, HD fan clutch and a shroud with the fan about half way into the shroud. Hottest I recall it getting was 205 while sitting on the Causeway near Sac on a 116 deg day and towing everything back from Lake Collins.
As far as the headers, I ran some on my '76 CC 4x4 Dually some years back. Did nothing for the engine temp. It DID make the underhood temps unbelievably hot though. I ended up cutting a few vents into the radiator core support to let more air in. That helped.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 04-16-2016, 01:12 PM   #7
storm9c1
*** That's interesting ***
storm9c1's Avatar
Re: Dumb Question
Not a dumb question. But headers won't help.
Things that WILL help:
- 7-blade HD fan with a new clutch. If you still have a stock 7-blade fan, good! Check or replace the clutch.
- Flush out the engine coolant really well, including the block.
- Tune the QJ one step richer -- this has REALLY helped with Eddy carbs on my big blocks.
- Check for vacuum leaks which will make an engine run lean.
- Advance timing a few more degrees, but don't let it ping.
- New 4-row radiator. It if was 30% blocked, rodding is only a temporary fix. Make sure fins are straight and not blocked.
- Make sure the shroud is good and fan blades are 3/4 recessed (blades covered) in it front to back.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 04-16-2016, 02:34 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Re: Dumb Question
From what I have read the aluminum radiators are really more efficient than the copper core we had in these trucks. A search on the internet will show they are better. If you are concerned about overheating and not about keeping the truck absolutely stock the aluminum one is the way to go.
Be sure and eliminate any other probable causes of overheating first as mentioned above.
06 Trailblazer
Old 04-16-2016, 08:27 PM   #9
A1971Blazer
A1971Blazer's Avatar
Re: Dumb Question
In past experience........those 454s tend to run hot a little hot....I had one years ago that wanted to overheat.....I threw money at the radiator to no avail....finally ran across some info (this was pre-google era) about putting a slight restriction in the cooling line where it went into the top of the radiator..
I made a do-nut type washer with a small shoulder machined on it to secure it right at the hose connection.
I can't remember the exact size.....and IIRC I made several before I got it right.............but what happened was, the thermostat opened at the same temp.......but the restrictor slowed the coolant flow enough to allow it to absorb a little more heat as it flowed thru the motor.....it worked......dropped the coolant temp about 20º.......still ran at 205º
If you're running an auto tranny......and you probably already have one........but you for sure need a heavy duty auxillary tranny cooler......that trans will get hot.......especially when towing.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 04-16-2016, 08:44 PM   #10
franken
Re: Dumb Question
People are all excited about aluminum radiators but aluminum conducts heat less well than brass and copper. The tubes in AL rads are also larger, which in my tiny mind means less coolant in contact w/ the metal and therefore less cooling.
This is much like the mini-starter trend. Car makers are under pressure from the government to reduce emissions and increase mileage. They're also always trying to spend less. More plastic, and other light materials may reduce the bloated weight of a vehicle, but that doesn't make the parts more efficient or better.
I'd use an original style radiator, shroud and clutch fan with a stock temp thermostat, and work from there..
Old 04-17-2016, 09:53 AM   #11
68gmsee
Active Member
68gmsee's Avatar
Re: Dumb Question
Pros and cons on either copper or aluminum. Cost being one. Copper is at a premium these days. The best thing for a person to do is to do their own research and ask radiator shops to decide which way to go. If I was going to go for the stock look I'd go with a high efficiency copper radiator but if it was a daily driver or work truck, I would not hesitate to go with aluminum.
http://www.cgj.com/2013/07/16/alumin...inal-thoughts/
http://www.caparadiator.com/aluminumvscopper.html
06 Trailblazer
Old 04-17-2016, 10:13 AM   #12
TJ's Chevy
TJ's Chevy's Avatar
Re: Dumb Question
Duramax diesel radiator and dual electric fans. On a 100 degree day kept my 496 below 220 and it had headers. You'll want a shroud as well.
Old 04-17-2016, 09:47 AM   #13
ranger danger
Re: Dumb Question
It does have a 7 blade OE fan and the fan clutch is new (6 months). Radiator is 4 core. Shroud and blade depth are good. The coolant was flushed out at the same time the radiator was rodded and I added one bottle of water wetter to it. I've sprayed the intake manifold, carb and brake booster fitting with carb cleaner looking for vacuum leaks and found none. Also replaced tranny vacuum lines and checked for leaks there. I am not Qualified to mess with the carb so Ill keep trying to find someone local that knows there stuff, that has been my biggest challenge!! I would really like to find a local guy who knows his stuff on these motors!
NRA Life Member
Old 04-17-2016, 11:19 AM   #14
nonstop
Re: Dumb Question
Just curious - what thermostat are you running? Mine will hit 225 at times with a 195 thermostat (too hot), but seems pretty happy with a 180, where it will run 195 to 210 - verified with infrared thermometer. I have tried a few different 195 and 180 degree thermostats, giving me the same results. Just something to keep in mind or try.
Old 04-17-2016, 04:10 PM   #15
ranger danger
Re: Dumb Question
It's got a 180* thermostat in it. It will run at 170-175* when the weather is down below 65* but as it gets hotter (above 78-80*) it will run at 185-195*. Then when the temps get over 85-90* It runs a steady 195-200* unless I'm in stop and go or uphill or with a load. Then it goes over 200* and as high as 225*. All of this is verified with an infrared thermometer.
NRA Life Member
Old 04-18-2016, 12:09 AM   #16
storm9c1
storm9c1's Avatar
Re: Dumb Question
OK, so if it gets hot in stop and go traffic plus pulling hills, that doesn't sound like carb jetting to me. Usually a carb-lean overheat condition will only be seen at speeds above 45MPH both pulling or cruising. And if your cooling system is up to the task, temps will fall back down when your speed is under 25MPH. But you are saying temps also rise at lower speeds, right?
I'm leaning toward cooling system issues now. If your rad was 30% clogged, I hope your cooling passages in the block aren't also clogged.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 04-18-2016, 06:45 AM   #17
ranger danger
Re: Dumb Question
The engine is a crate motor with about 15k miles on it. The radiator is OE I believe. I am leaning towards a radiator as well. What are some of the best sources for Aluminum radiators? Would it be best to get one with or without electric fans? I'm looking for simplicity and function.
NRA Life Member
Old 04-18-2016, 01:28 PM   #18
storm9c1
storm9c1's Avatar
Re: Dumb Question
If you have a good 7-blade OEM fan with a good heavy-duty or severe-duty thermal clutch, and a good shroud, then you shouldn't need electric fans. Keep it simple.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
