Old 04-19-2016, 07:40 PM   #1
lilrobo
obd2 connector help
guys i have a 55 with a 5.3 from a 06 truck and computer from 02 camero ,, all has been great , i have loaded tunes and played with it tons ,, i did a push button start and now i cant load a tune, it says cant connect and to check connection ,, i can scan and do log runs , so i think i am linking up to ecm ??
i have 4 wires
purple = data
black = ground = chassis
blk/wht = ground = signal
orange = battery
the ground check out i check with ohms all good , the orange is 12 volts hot all the time ,, how do i check the data port ? i dont understand nothing changes when i go in to acc mode . or what is suppose to happen that mode
thanks
lilrobo is offline   Reply With Quote
Old 04-20-2016, 02:20 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: obd2 connector help
i have 4 wires
purple = data
orange = battery
thanks
It sounds like a wiring problem. Are you sure you didn't mess up the "data" wire when you installed your push button start?
Hart_Rod is offline   Reply With Quote
Old 04-20-2016, 04:44 PM   #3
lilrobo
no i am not ,, right now the 4 fuses under the hood that came with the harness are dead in the acc mode ,, now after i start they are hot ,, i am able to read and scan the ecm after its running
i have a acc wire messed up somewhere
thanks
Old 04-25-2016, 08:23 AM   #4
lilrobo
all good wiring issue with my push button ,,,, now i need to figure out shifting in the tune
thanks
