Old 04-21-2016, 12:01 AM   #1
62jimmy
axle saver bearings?
Hi, I pulled the axle on the donor '65 12 bolt that I plan on building for my truck. Everything looked pretty good, but both axles both have about .020 to .025 wear on the bearing load surfaces. I'm trying to keep this truck on a budget, so I really didn't want to invest in new axles. I'm assuming I would need to use axle saver bearings with this amount of wear? Anyone have experience with these?
62jimmy is offline   Reply With Quote
Old 04-21-2016, 08:37 AM   #2
jjzepplin
jjzepplin's Avatar
Re: axle saver bearings?
I've used them on several cars and trucks. They just ride on a spot of the journal that is still in good shape and I think they have larger bearings inside than stock. They install the same way. You'll be fine.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-21-2016, 09:00 AM   #3
Bad4wd
The Napa bearings are better than others because they don't run the inner rubber seal which prevents oil to the bearing.
Bad4wd is offline   Reply With Quote
Old 04-21-2016, 09:24 AM   #4
vince1
The 71 3.07 diff that I way overpaid for is almost shot. Those axle bearing surfaces were really chewed up so yes you can get another go with the other bearings. About the internals, that's another story.
vince1 is offline   Reply With Quote
