04-21-2016, 05:39 PM | #1 |
Alternator
Bought an reman alternator from autozone, battery still drains after a few starts or sitting for a few days without starting. Had it tested last night at autozone and it is 12volts with the truck running. the manager said it was either the alternator or my wiring.
Had a proform one wire alternator on for a while it would run the batt. down too, also had an advance parts and it was totally rusted inside and ran the batt down and it would just die while driving with the lights on. I have new battery cables and a new batt. from walmart that is the correct cranking amps. I have a butt connector crimped on the small starter solenoid wire, but that wire has been cut and twisted since I've had the truck. Info: 1984 c10 305/350
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
04-21-2016, 09:13 PM | #2 |
Re: Alternator
I wonder what year the truck is and what alternator is in it...
You need a voltmeter or DVM. Measure the voltage at the battery with the engine not running after some hours, and running. People at Autozone will tell you your dead cat needs a bath. I took a battery to them and at 9V they said it might need a charge. Right. |
04-21-2016, 11:23 PM | #3 |
Re: Alternator
I just went through my 3rd alternator from advance auto. None lasted more than 150 miles, they would charge, but would draw almost 1 amp whole the truck was parked. I dug out my old delco, took it apart to paint it, and it works like a champ.
04-24-2016, 03:16 PM | #4 |
Re: Alternator
Does Autozone have a beanch alt tester to say 100 % it working. Do you have a batt charger, Get the Batt charged then test the batt in the truck with the alt in running test the Batt under load see if reading are good. If not you got a short. FIRE WALL BLOCK CAN BE A BAD CONNECTION ( RED WIRES ). IF GOOD THERE check fuses and all go from there, all main connection lights, sockets, shorting bulbs, light switch, bad grounds.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
