04-22-2016, 12:56 AM | #1 |
60-66 steering wheel column swap
what's up crew!! looking for tips or ideas . Anyone who has done a steering wheel column swap for a 60 to 66 truck
04-22-2016, 07:17 AM | #2 |
Re: 60-66 steering wheel column swap
I installed a late 70s Chev G series van with tilt in mine as the key is still on the dash. Had to cut the lower shaft and install a u-joint when we did the power steering conversion. Works and looks good. Happy with it.
04-22-2016, 09:39 AM | #3 |
I used a floor shift column & intermediate from a 69 C10. You can see what I did starting with around post #62 in my build.
http://67-72chevytrucks.com/vboard/s...=627495&page=3
04-22-2016, 09:46 AM | #4 |
I used a 71/72 c10 tilt and it went in easy using the 65 mount and 71/72 intermediate shaft. I also used the cruise control stalk from a mid 70's van as well.
Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-22-2016, 01:34 PM | #5 |
I have a 72 tilt column in my 65 Suburban and was lucky enough to be able to use my original deluxe wheel. And as stated above, key is still in the dash. I'm thinking of having the end from the 72 shift lever welded to a 64-66 lever for a little more original look.
04-22-2016, 10:48 PM | #6 |
I also used a 72 Van Tilt in my 64. I bought it off eBay for $99.00 + $20.00 shipping. I was the only bidder. I had to move the neutral safety switch down the column a few inches to clear the mounting bracket. I slid the column down as close to the dash as I possibly could for more gut room and I always leave the wheel in the full tilt up position - again for more gut room. I'm not a big man - 5' 9" & 187 LBS.
04-24-2016, 06:34 PM | #7 | |
04-25-2016, 04:07 AM | #8 |
WOLFMANmike,
The A/C vents came off a 64 Chrysler New Yorker & yes they are functional. When I bought the truck it already had Vintage Air but it had the plastic cheap looking vents. I just didn't like the look of them. I found these during a half off day at a local self service yard (like Pick N Pull) for $6.00 each. I just found a center vent on eBay but that one cost me $26.00. I just installed it this past weekend. |
04-23-2016, 03:33 PM | #9 |
Very nice ! looks clean .. That's the look Im shooting for as well.. Did you have trouble mounting it using the stock E brake plate ?
04-24-2016, 02:13 AM | #10 |
I have a beautiful van column I bought years ago but I just bought a new Ididit tilt column. I'm kind of tempted to run the van column. How do I do it? Or is there someone I can ship it to that can modify it?
My mother is a recent cancer survivor and this truck build is for her |
04-24-2016, 10:05 AM | #11 |
im currently working on mine .. I bought the Column swap kit for my truck .. Came with everything I need to install. Seams like everything will be straight forward swap. However i suspect I'll need to do some drilling and small adjustments.. Nothing is ever a bolt on swap as they say it is. I'll send you some pictures as I go along. I just started it yesterday... The remonval was easy !
Posted via Mobile Device |
04-24-2016, 11:11 AM | #12 |
I also have the van column, but now that I am using a 1987 truck with cruise control on column and the motor and tranny I may just use it and sell the van column.
04-26-2016, 10:36 AM | #13 |
I have a 1974 PS gear box and the intermediate sleeve with DD shaft. Not installed yet. Just bought a 3/4" X 3/4" (DD both ends) steering universal joint too. My plan is to join the 1974 intermediate shaft to my 1965 shaft with the U-joint. My 1965 shaft is 3/4" round and so I'll cut it to the proper length and then have the machine shop make the end into a DD shape so it fits into the U-joint. The U-joint has bolts that go though the DD shafts so they can't pull out. I will post pictures once I get to that point.
It doesn't give me a tilt column but I can always get a tilt column later if I'm not happy. The U-joint was only $30.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
04-26-2016, 10:39 AM | #14 |
Subscribed...
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
04-26-2016, 08:39 PM | #15 |
WOLFMANmike,
I'm not sure about the Economy Heater. When I bought my truck it already had the Vintage air in it. The Chrysler A/C vents have 2" hose inlets. I just swapped out the plastic Vintage Air vents for the Chrysler ones. If the Economy Heater has 2" outlets for heat I'm pretty sure they would work though. |
04-26-2016, 11:15 PM | #16 | |
Yesterday, 10:21 PM | #17 |
One thing, I grabbed a column out of a md 1980's GM 1/2 ton van & the hook up for the transmission is on the oppisite side of what I needed. I'm not sure it will work, just tossing it out there.
