Old 04-23-2016, 10:11 PM   #1
1972BlueC20
1972BlueC20's Avatar
Factory Gauges (reproduction) Questions!!!
Just finished my conversion from idiot light dash to gauge cluster.
Trying to get some info on the stock (reproduction) gauges and how to read them.
Battery Gauge :
Seems to lean to the far right mostly near the C (I'm assuming that's Charge?)
Is that normal? Sometimes will be in the middle.
Temp Gauge :
Does the middle and far right (Hot) translate to a rough temp? For example if the needle is dead in the middle is that like 170-180 degrees? If on Hot? Degrees?
Oil pressure gauge :
Any idea if in the middle and far right towards H what the actual PSI translates to? Mine seems to lean towards the high pressure zone. (Crate engine with 10k miles, vortec heads, 330 hp sbc 350)
Also my new fuel gauge is a little jumpy more so that the gauge it replaced. It works and is accurate, but seems to be a tad jumpy and has more movement with driving. Any way to fix this? I have a ground wire running from the back of the fuel gauge housing to bare metal under the dash. Does this sound like a Ground / connection issue?
Thanks!
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 04-25-2016, 09:53 AM   #2
1972BlueC20
Re: Factory Gauges (reproduction) Questions!!!
ttt, anyone?
Old 04-25-2016, 10:36 AM   #3
OregonNed
OregonNed's Avatar
I'd be interested to know the answer to these questions as well.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 04-25-2016, 10:37 AM   #4
1972BlueC20
yep. hopefully someone who knows will chime in for us!
Old 04-25-2016, 12:07 PM   #5
DBK81
DBK81's Avatar
I'll take a closer look at my factory guages when I go home for lunch.
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 04-25-2016, 12:16 PM   #6
davepl
davepl's Avatar
I made this chart for my temp sender. Doesn't show you where a particular ohm reading is on the gauge itself, but it's a start. I don't think you'll find more than people's opinions on this question unless you dig the data up, maybe do some testing yourself.
If you could figure out what ohm level is what on the gauge, we could map it to an exact temperature with my chart.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
