04-24-2016, 09:41 AM | #1 |
Ex military truck gears
I'm thinking to buy an 1985 ex military K30 6.2 liter diesel, but I know that military trucks have a modified transmission with different gears.
This one is an automatic 3 gears, do you think it's a boring drive and I should change the transmission ? |
04-24-2016, 09:51 AM | #2 |
Moderator
Re: Ex military truck gears
The CUCV axle gears are 4.56:1
The CUCV TH400 has the same gearing as the Civilian version. Will you be running it on the highways or locally?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
04-24-2016, 10:07 AM | #3 |
I will run it mainly locally, I'm looking for something with a lot of torque for have fun, not for higways
04-24-2016, 10:09 AM | #4 |
04-24-2016, 09:55 AM | #5 |
Its got a diesel turbo 400 and is a 4.56 gear ratio all oem gm parts.
04-24-2016, 09:58 AM | #6 |
Next!
Nothing special about the trans in a CUCV, all TH400s
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
04-24-2016, 04:45 PM | #7 |
A diesel with 4.56's sounds like just the ticket, then.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
04-24-2016, 05:10 PM | #8 |
04-24-2016, 05:40 PM | #9 |
he means it will do exactly what you are looking for
1981 Silverado C10 LS/4l60e My truck may be loud and ugly but I love her like bacon |
04-24-2016, 06:06 PM | #10 |
Good, thanks for the infos
04-24-2016, 08:31 PM | #11 |
Sorry. What he said.
04-25-2016, 04:06 AM | #12 |
04-25-2016, 12:34 PM | #13 |
I didn't realize you were from Italy either. With your username and Avatar Would have never guessed. I didn't know there were rednecks in Italy.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
04-26-2016, 11:09 AM | #14 |
I was also unaware!
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
04-25-2016, 01:11 PM | #15 |
With a 6.2, TH400, 4.56 you'll be at very high RPM on the highway (unless you have significantly larger tires than stock). It'll work well at low speed though.
1973 C20, 350/350 |
04-25-2016, 02:33 PM | #16 | |
I was also wondering to put dually wheels on the truck, (I'm a dually fetishist) what do you think about ? I could have problems to the rear axle ? Last edited by Redneck79; 04-25-2016 at 02:42 PM. |
04-25-2016, 03:05 PM | #17 |
Great looking truck!
As an aside, my dad was project manager for the CUCVs back in the 1980s at the U.S. Army Tank-Automotive Command (TACOM). They had some early teething problems, but worked out the kinks early on. They're solid trucks. After all, they're Chevys!
Semper Paratus |
04-25-2016, 03:41 PM | #18 | |
I want to add spike lug nuts, do you can suggest me a link where I can buy the right ones for the truck ? |
04-30-2016, 10:44 AM | #19 | |
1985 Chevrolet Custom Deluxe 4x2 , 305 v8 , 700R4 transmission |
05-08-2016, 09:33 AM | #20 |
My unit received our first CUCVs in about 1984 and from what I recall there were some early problems with the glow plugs or injectors on the diesel engine.
We were in the field using the trucks and had to keep swapping them out so that each one could be taken to the dealer for the GM fix. The fix apparently was not complicated, because it only took one day in the shop. However, most of the drivers thought it was fine to get out of the field and get paid for relaxing at the GM dealer waiting for the truck to be ready. We then took them on an exercise to Korea in March 1985 and they were very reliable. It was great to have a heater in every vehicle, since the old jeeps (that the Blazer CUCV replaced) usually did not have a heater and we had to completely remove the tops in the field. I did notice a big difference in gearing from the pickup version (4.56 gears) to the Blazer version (not sure of gears), which made highway travel a lot quieter in the Blazer. Bruce |
04-25-2016, 11:22 PM | #21 |
I imagine you'd need a flatbed in order to fit dually 36s. The internals of the rear axle are the same for 3/4 ton, 1 ton SRW, 1 ton DRW, and CUCV truck (which I think is just a 1 ton SRW). However, the DRW axle is wider. I'm not sure if you could fit dually rears with the axle you have, seems unlikely with the tire size you have. Additionally, the front setup is wider... I'm not sure whether it's the center section or just the hubs on squares, I know modern trucks it's the center section but someone said it was just the hubs on squares.
1973 C20, 350/350 |
04-26-2016, 10:37 AM | #22 |
Moderator
Some M1028 and M1031 CUCV can be found with dual wheels. It was a motor pool add on kit for the M1028 & M1031 making it an M1028-a2.
http://67-72chevytrucks.com/vboard/s...d.php?t=546148
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-26-2016 at 10:43 AM. |
04-26-2016, 08:49 PM | #23 |
Next!
Dually CUCVs
M1028a2 NP205 converted M1031 or M1028a1 M1028a3 NP208 converted M1028
04-30-2016, 07:04 AM | #24 | |
I found this info about CUCV axles by models, do you think are correct ? M1009 10 bolt axles front and rear with 3.08 gears and a Gov-Loc in the rear (Not Dana 60 front and 14 bolt rear like some believe) All other CUCV’s Dana 60 front Front Capacity 4.5 Quarts 14 Bolt FF rear with Detroit locker and 4.56 gears (some have a true-track locker in the front as well, but it is rare) Rear Capacity 5.4 Quarts M1028 needs GM additive |
04-30-2016, 08:30 AM | #25 | |
Moderator
Axle capacity is in PINTS not quarts... The M1028A2 and A3 should have the transfer case of the vehicle it was converted from. M1028 dually conversions should still have the NP208 transfer case M1031 dually conversions should have the NP205. The CUCV WIKI on the Steel Soldiers forum. http://www.steelsoldiers.com/showthr...7427-Cucv-Wiki
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-30-2016 at 08:35 AM. |
