Old 04-28-2016, 07:23 AM   #1
dragn91
dragn91's Avatar
C10 vs c20 front crossmembers are they the same?
I want to section a crossmember for my c20 so I have it ready for when I swap the engine in a couple months. I can't find a definitive answer on if the c10 crossmembers are the same as a c20. I have access to a lot more c10 parts than c20. Anyone know for sure? I know the c20 uses larger u bolts on the lower arms but can I just drill those larger?
dragn91 is offline   Reply With Quote
Old 04-28-2016, 09:49 AM   #2
SCOTI
SCOTI's Avatar
Re: C10 vs c20 front crossmembers are they the same?
Lower shaft u-bolts aren't different. The upper shaft studs are 9/16" for C20/30 & 1/2" for C10's. The x-members will interchange but will require using the correct upper arms for the specific x-member.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-28-2016, 12:10 PM   #3
dragn91
dragn91's Avatar
Can i just drill them out and run grade 8 bolts and put the 3/4 ton arms on when I swap them?
Old 04-28-2016, 01:05 PM   #4
SCOTI
SCOTI's Avatar
Yep.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
