05-01-2016, 12:38 PM | #1 |
Where is a good place to tap in for gauge light
Is splicing into the headlight switch a good source?I would like to able to see my temp gauge at night.
05-01-2016, 01:14 PM | #2 |
Re: Where is a good place to tap in for gauge light
if you want it to dim/bright the same as your other gauges use the grey wire off the fuse panel
it is the same wire that feeds all the other gauge lights (follow the 16-gy wire from the instr panel bulbs) this will give you a fused dimable light, hooking direct to the headlight switch will not be fused
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-01-2016, 01:21 PM | #3 |
Thanks Ogre.
