Old 05-04-2016, 04:18 PM   #1
Bonzai
6.0 from 2013 Chevy express
Need some help gear heads... Trying to decide if I should buy this and put into 72 c10.. Is it an engine that can easily tune for more hp and what transmission should I find.. It's priced nice for an engine with 30k
Bonzai is offline   Reply With Quote
Old 05-04-2016, 04:31 PM   #2
Custom 68
Custom 68's Avatar
Re: 6.0 from 2013 Chevy express
4l80 for the transmission.
As far as tuning yes they have been around a long time and lots of tuning is available. A cam and the tune will get you a long ways on these.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 05-04-2016, 08:12 PM   #3
Bonzai
Thank you for the response next question... Will any model year on a 4l80e work on this engine? Thanks for dealing with my dumb questions I'm learning as I go
Old 05-04-2016, 09:56 PM   #4
99turbogmc
For ease I would do a 4l60e, there cheaper and easier to work with.
It's not that easy if your not mechanically inclined. You need motor mounts, trans crosse member, computer, wiring harness, find a easy to run your fuel, regulater, lines, ext. radiator mods, driveshaft gauges ext. trust me, I know. Everything I own is lsx based or swapped. Well worth it if you have the knowledge
99turbogmc is offline   Reply With Quote
Old 05-05-2016, 06:17 AM   #5
I guess I'm a gear head when it comes to 67-72 GM Trucks. I answer a lot of questions for members here. But I don't know a thing about 2013s. Maybe ask in a forum for that year or the LSX swap forum
Old 05-05-2016, 09:43 AM   #6
Willie Makeit
Willie Makeit's Avatar
go with your instinct and use the 4L80e, cause you're gonna eventually need it if you install the 4L60e behind the 6.0 and put any sort of tune other than stock (ie: torque management) on it.
Willie Makeit is offline   Reply With Quote
Old 05-05-2016, 10:27 AM   #7
70blackfish
I was told to use the same year trans as the engine...my friend did not and had problems...
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 05-06-2016, 09:27 PM   #8
cableguy0
Im going to move this to the LS forum for you..
DO NOT USE a 4l60e behind that 6.0 unless you like replacing your transmission. The 6.0 would have had a 4l80e behind it from the factory. I don't know the year splits off the top of my head for which year transmission you will need but there are compatibility issues with different year units. Can you get the transmission from the van? It will make life much easier because it will be a 2wd unit. Most of the trucks with a 6 liter were 4wd making 2wd transmissions harder to come by.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-06-2016, 09:57 PM   #9
foamypirate
foamypirate's Avatar
4L80Es pretty well interchange between about 94' and up. They didn't get all the weird changes 4L60Es did, like TCC lockup clutch material changes and apply strategies (PWM, EC3, etc). I've got a 99' 4L80E from a 5.7L Express van behind my 05' 6.0L LQ9 w/ a torque converter for a 91-97' 4L80E, no problems. It works great.
foamypirate is offline   Reply With Quote
Old 05-06-2016, 10:35 PM   #10
storm9c1
*** That's interesting ***
storm9c1's Avatar
Here's a decent link for info:
https://sites.google.com/site/sloppy...-ls/4l80e-info
The one thing that caught my eye is the first bullet point. I haven't seen the "bad" connector on any 4L80E past about 1994, even though the link says '91-'96. So I agree with "foamypirate" that you want 1994+. I think there is a subtle solenoid different in '93 back, but I can't recall. Perhaps Cline can clear some of this up if needed.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 05-07-2016, 09:19 AM   #11
Heavymetl
Aside from the obvious strength issues, I like the 4L80E's gear ratios MUCH better than the deep 1st gear of the 4L60E.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 05-07-2016, 07:44 PM   #12
clinebarger
'91-'93 had a Bosch Harness & Bosch EPC Solenoid, The Harnesses & Connectors have all sorts of issues, The EPC Solenoid was not known for it reliability either, For '94 A Delphi Harness & a Holley EPC Solenoid was introduced....Far better designs.
In 2004, GM started using a Borg Warner EPC Solenoid with a different connector, The Borg Warner solenoid suffers from performance degradation after about 50,000 miles unlike the Holley design.
Leaky Harness Pass Through are common on all high mileage 4L80E's.
clinebarger is offline   Reply With Quote
Old 05-08-2016, 10:26 PM   #13
Willie Makeit
Thank you sir.
Old 05-09-2016, 12:11 AM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Willie, I really think a heatshield or airbox would be a benefit to you from a performance IAT/standpoint. Have you logged your IATs during a drive at all and seen what they average?
With your smoothed engine bay, the typical airflow characteristics of these trucks, and the amount of underhood heat that blower generates; I'd be inclined to think that filter is chooching decently warm air. At least in traffic/carshows/staging scenarios.
You could put together a pretty straightforward shield (and possibly a creative inlet, if you don't already have one I can't see) and you could knock a few points off your IAT's and really combat heatsoak if you live in a warm area.
/unsolicited advice
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-18-2016, 10:12 PM   #15
ChuckLee
We have a 2012 Express 3500 15 passenger with the 6.0/4l80
Let me just say.............it's a BEAST even in that van. You are going to have lots of fun!
ChuckLee is offline   Reply With Quote
Old 05-18-2016, 10:47 PM   #16
clinebarger
Are you sure it has a 4L80E?, A 2012 should have a 6L90E.
Old 05-18-2016, 10:21 PM   #17
zach_carver
zach_carver's Avatar
From what I'm learning if your doing dbw watch what throttle body and all your using if going with a 4l80e. I've run into wanting to add a 80e now that my old 70e give up. And it would cause a lot of work now that it's all tuned and everything for the 70e. Your gonna love the LS engine though. Mine has a stock ls2 and it's a blast to drive..
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 05-18-2016, 11:52 PM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The TB doesn't care what trans is in the truck. Your tuner makes the changes to the trans and VSS/ISS settings, and thats the majority of it. Yes, if you had a lot of road tuning done the different final ratio on the trans will affect your shift points, but its not difficult to do. You'll have to add the secondary speed sensor to the harness.
Old 05-18-2016, 11:30 PM   #19
ChuckLee
good catch. u r right.
Old 05-07-2016, 01:59 PM   #20
MalibuSSwagon
L96 - 6.0L with L92 heads. I'd get it and slap an LSA supercharger on top.
MalibuSSwagon is offline   Reply With Quote
Old 05-08-2016, 09:51 PM   #21
Willie Makeit
I concur.
p.s. yes, it has a 4L80 behind it.
Old 05-08-2016, 09:54 PM   #22
foamypirate
Originally Posted by Willie Makeit View Post
I concur.
That is super clean! Very nice job there, sir!
Old 05-10-2016, 09:56 AM   #23
Pulse_GTO
I concur.
Very nice! I'm trying to do the same. Do you have a build thread?
Pulse_GTO is offline   Reply With Quote
Old 05-10-2016, 10:29 AM   #24
Willie Makeit
no sir, but i'll be glad to answer any questions or help out any way i can.
Old 05-18-2016, 04:04 PM   #25
ChuckLee
I concur.
whoah! lol
