Can we see pics of your windshield washer mod?
From what I've read on here tonight, a lot of guys have figured out that the original washer pump sucks. I know mine hasn't worked since 1991 and dad never remembers it working!
Can you guys post pics of what you are using and what make and model vehicle it came out of? Dad and I might hit the junkyard next week after the rain lets up. |
Re: Can we see pics of your windshield washer mod?
Make sure it's a positive displacement pump and not a rotary pump - most rotary pumps can't even lift fluid out of the jar and MUST be below the jar, so they don't work. Anything designed to pull fluid should be fine, I just had a lot of trouble finding such a thing!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Post #111 pic 3 http://ls1tech.com/forums/conversion...-c-10-a-6.html This is out of a late 80's Chevy van, and they have a real similar washer bottle, but I used my factory one and just added a bracket for the pump.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Old member
Sorry I don't remeber what model it came out of but it was a little Chevy sedan maybe a malibu. It has the pump mounted on the side and I wired it to work off the orignal switch. Hot is always on and the switch grounds it. I also redid the spray nozzles to come out at the wiper arms and mount on the wiper to get a full swipe with water instead of just a straight stream in the middle it covers the whole area with water.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#5 | |
#6 | |
I'm going to copy your moves (highest form of praise? ![]() Thanks a ton for that pic. |
![]() Join Date: Jan 2001
My setup is very similar to Andy's. Mine came out of an S-10 and works great.
If someone could figure out the original van application so that we could RockAuto it or grab it on Amazon, that'd be great. But "80s van" is still a little too broad!
yeah I suppose I could benefit from actually having this feature work on my truck
The more I look at that Is1nova71, where is the hose that goes from the pump to the squirters?
Here is what I think you have. Is this the pump? http://www.carpartkings.com/media/ca...n61-15_fro.jpg If so, does the nozzle to the squirters come out of the bottom of the pump? |
#13 | |
I used a $20 generic pump from the auto parts store and mounted it in the original location. Works pretty good.
#15 |
I really want to figure out a way to use the original tank on my Panel build, because I have the only black one I've ever seen:
![]() But for my pick up, 'Ol Green, I used one out of a 10 year old Kia.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#16 | |
BTW, I also have a black bottle that I found in a 67, and was wondering how common they are. |
#17 |
#18 |
Not stock looking but I used one out of a '96 s10 blazer I parted out. I kinda contours the wheel well on the passenger side. It also base two pumps (one for back glass on blazer) so if it goes out I can just swap them!
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
#19 |
Old member
For got to add the switch wiring picture. Here is how you wire the pump.
The pump gets 12 volts straight off the battery. The ground runs back the switch so that when you push it in it grounds the pump and sprays water. ![]()
#20 | |
I think I can make my own bracket if I have to just buy the pump. Andy, thanks.....when dad and I get to the junkyard to look for pumps I'll have a look also for clips such as these on your wipers. Pritch: same here on using the original bottle. Wow, how do you see the fluid level on that black bottle? Last edited by In The Ten Ring; 05-05-2016 at 10:03 PM. |
#21 | |
#22 |
6>8 Plugless........
![]() Join Date: Sep 2007
I really like Andy's set up. I was actually looking to try to get the nozzles on the arms too. In to see what he used.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#23 |
Old member
To get the plastic to hold on to the arm boil some water in a pot and have some vise grips ready to clamp them in place. Get the water boiling good and drop them in for a minute are so then pull them out and put on the arm upside down and clamp them in place to cool off. Once they cool off you just unclamp them. They will confrom to the arm and can pop on and off easy.
This is how I did mine anyway. I did mine on top of a kerosene heater in the garage so I wouldn't have so far to go with them when I pulled them out of the water. You don't want them to get so soft you melt them just enough to make the clip part flex enough to squeeze it. ![]()
#24 |
Andy, do you know what year range and vehicle the nozzles cam off of? Thanks.
#25 |
Old member
That was many a moon ago! Like 15 years ago. Sorry no I don't I just started walking through the Junkyard until I spotted them.
