Old 09-28-2003, 08:25 PM   #1
1972ChevyGuy
1972ChevyGuy's Avatar
Wheel Stuck?
Cant get the thing off to save my life.... 3 guys couldn't do it. I put lugs back on and tapped em with a hammer to see if I could break it loose but she wont budge. Any ideas why? Or how to get it off? (5 lug rallys on a 72 c10) if it matters. Thanks - Jeremy
1972ChevyGuy is offline   Reply With Quote
Old 09-28-2003, 08:29 PM   #2
Blue_71
Bloo
Blue_71's Avatar
it may or may not work, but i usually make sure whatever is holding it up is steady, sit on the ground, and kick it on each side with my foot, one side at a time... ussually it'll break em loose
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 09-28-2003, 08:41 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That's always a fun one. Do this:
Put it down on jackstands and remove the lug nuts. Then hit the inside sidewall of the tire pretty good with a sledge hammer about twice. That'll do it and won't hurt the tire.
I used to have to do this to every single one of our trucks when I worked as a mechanic for the post office.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-28-2003, 08:44 PM   #4
1972ChevyGuy
Thanks fellas, any idea what causes it? - Jeremy
Old 09-28-2003, 08:47 PM   #5
Tx Firefighter
Overtorquing the lugnuts will pucker the center of the wheel tightly onto the hub. Also rust on the hub with aggravate the problem. Overtorquing can also warp brake rotors too, causing pulsing brakes.
Old 09-28-2003, 08:49 PM   #6
1972ChevyGuy
I have my gun set on 85 lbs, too much? Thanks again - Jeremy
Old 09-28-2003, 08:59 PM   #7
Truckhead
18436572
Truckhead's Avatar
Before smacking the tire thread one of the lugs on a couple turns so when the tire does come off it won't fly across the room.
Truckhead is offline   Reply With Quote
Old 09-28-2003, 09:33 PM   #8
70cst10_05
70cst10_05's Avatar
is it the front or back??if its the front, turn the wheels all the way to one side, and wedge a piece of wood or somethin between the wheel and the frame or somethin sturdy, then start the pickup and turn the wheel against the wood or whatever, only had to do it once, worked like a charm
1970 Chevy CST/10
1970 Chevy CST/10
1972 Chevy C/10
1972 Chevy Suburban K/10
2019 Silverado 2500 Duramax
Kevin
70cst10_05 is offline   Reply With Quote
Old 09-28-2003, 09:42 PM   #9
1972ChevyGuy
Rear wheel. I felt pretty dumb, I've took my wheels off a thousand times and after I took the lugs off and tried to pull, I was like.... what the hell?!?!?!?! So I jacked the other side up and took a wheel off just to make sure, lol. Its gettin dark so I will try to beat the crap out of it tomorrow Thanks - Jeremy
Old 09-28-2003, 11:21 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Last month when longhornjeff gave me a set of 16 inch rims/tires for the one ton, I knew the old rims would be stuck like a mo-fo. Since I don't have a sledge here, and we were working on a driveway with a bit of a hill (I didn't want the truck on the jack for very long) I loosened up the lignuts a bit (with teh truck on the ground) and then grabbed the bedside and pushed it back and forth pretty violently. I heard each wheel pop loose within a couple shakes.
As for jacking it up in the driveway with a hill, i did anchor it with another truck.
Old 09-28-2003, 11:22 PM   #11
Longhorn Man
If you coat the threads and the center hole with some anti-seize compound, it will help prevent this from happening again.
Old 09-29-2003, 02:06 AM   #12
paintpyro
paintpyro's Avatar
Ive got that problem. Mine is from the powdercoating and clearcoat. Too thick. I used a large puller hooked on through the holes of the ralleys. Crank it a bit and they pop right off.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 09-29-2003, 12:20 PM   #13
oldsub86
Loosen but do not remove the lug nuts. Then drive around a bit turning back and forth. The side pressure from the turns should break it loose from the hub.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 09-29-2003, 01:02 PM   #14
Slammed67
Progress = 0%
Slammed67's Avatar
I was going to suggest the same thing as oldsub68. Just back the lugs off a turn or two then drive it down the street turning the wheel back and forth. It should break them loose.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
