05-08-2016, 07:49 PM | #1 |
GMC 2wd to 4wd conversion
Going to be doing a conversion on my 64, putting a set of 73 3/4 ton springs and axles in, and curious if anyone has put a front axle and springs under their 2wd? Know basically how I'll do it but pictures or input from someone that's done it would be worth having
05-09-2016, 09:43 AM | #2 | |
Re: GMC 2wd to 4wd conversion
- Patrick 1964 GMC pickup lwb ~ My newest build! 1937 Ford Coupe ~ Custom frame, LS1, quickchange 1950 Chevrolet 3100 ~ Bagged (Sold) 1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car) 1967 Chevelle ~ 454 Triple Black (Sold) 1964 Chevrolet Impala SS (Sold) |
05-09-2016, 11:40 AM | #3 |
Thanks, I'll be sure and keep doing searches, This forum is great
05-10-2016, 12:51 AM | #4 |
60-66 Nut
I would recommend checking out the 4x4 section of the forum. I would think the info you are looking for could be found there. The frames are basically the same '63-'72.
05-11-2016, 08:33 AM | #5 |
1961 crewcab
check out my suburban build:
http://67-72chevytrucks.com/vboard/s...d.php?t=448681
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
