05-09-2016, 08:43 PM | #1 |
Lifted 89 K5 gears
I have a lifted 4x4 89 Chevy K5 (350 TBI/700R4) on 37's. I'm wanting to change the gears to 4:88 or 5:13.
I think these are the ones I need for the rear? http://www.summitracing.com/parts/rmg-6901691/overview/ But, I can't find the part number for the front set, unless it is the same front and back? Thanks guys. |
05-09-2016, 10:07 PM | #2 |
Re: Lifted 89 K5 gears
I'm pretty sure the gears are the same F to R on the 10 bolt. Low pinion fronts drive on the coast side of the gear instead of the normal drive side. Simple thing to do is order from Summit using the phone instead of your computer.
05-10-2016, 08:30 AM | #3 |
Yeah, when it comes to differential parts it's best to talk to someone to make sure you get what you need. If Summit can't give expert advice, call someone like Randy's Ring & Pinion or Reider Racing. They are specialists and will sell you the right stuff
05-11-2016, 10:42 PM | #4 |
Id put a bigger axle in off a 3/4 ton truck with 4:10s
For 37"ers 4:10s would work for me. Unless your building a race truck or sumpin
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
05-13-2016, 02:05 PM | #5 |
He has a 700r4. He needs 5.13 ideally. You're located in usa. I'm sure there is a 4 wheel parts store somewhere. Call one of those. They can typically have them next day.
05-20-2016, 06:03 PM | #6 |
Thanks guys. Does having the stock gears in it, hurt the transmission?
05-20-2016, 07:44 PM | #7 |
Yes. Excessive heat buildup and low line pressures are detrimental to a 700r4. Help it out and put a large cooler inline.
05-21-2016, 08:08 AM | #8 |
user # 2756
My 83 has the 700r4, w/ 37" tires and 4.56 gears. It seems to do real good.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
06-03-2016, 09:29 PM | #9 |
Thanks guys for the help. Is brand name important in ring and pinion? Are Richmond's good? It looks like through summit racing 2 sets of Richmond ring and pinion and 2 install kits will run about $600, does that sound about right?
http://www.summitracing.com/parts/rmg-6901711/overview/ http://www.summitracing.com/parts/rmg-8310211/overview/ |
