![]() Join Date: Feb 2009
Question about stainless steel - door sills
I haven't removed the windows, seat or gas tank yet, but as far as I can tell I'll have two items with rust worth mentioning. One is the diff. cover, the other is the bottom of the LH door sill. Makes sense it would only be that side, because it was a driver (snow) pre-1995. Not knowing anything about stainless steel, I'm still surprised there was so much rust. The floor board is unphased.
I'll spend 10 minutes a night x7 getting the rust off. Brush on some vinegar a few times a day, scrub at night and start over again. When it's all said and done it will look better than new, at least on top will. My seeking education is....are these solid stainless? What level of integrity is compromised by sanding these down?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: Question about stainless steel - door sills
If they were stainless, there shouldn't be any rust. There are of course different grades and some will show surface rust. I don't believe the originals from the factory were ever stainless.
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
I thought they were stainless. If not, what are they? There's deep surface rust, especially along the bottom outer edge.
I've spent a little time with 80 grit on top (no rust). From this angle, it appears it will sand to like new. Even with 80 grit it appears much improved.
They are chromed steel and rust very easily. There are reproductions made in stainless. I've put perfect OEM sill plates on and had them rust in a year. That's why I sold off my stash of N.O.S. and pocketed the cash. It's stainless sill plates for me from now on
#5 | |
It seems that you have CDO too!
I definitely have a touch of OCD, but had never heard of CDO. I don't think you meant collateralized debt obligation, but I do feel a sense of debt for this truck.
![]() I suppose "someone" could shine these as good as it gets and clear coat. Hmmm. I'll get an OER regardless.
#8 | |
CDO is OCD, it's just in alphabetical order like it should be!
Last time i checked stainless is non magnetic, least my fridge is anyway, stick a magnet on it to see.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
I have some that have been sandblasted. I was thinking about getting them powder coated black or...
that's a great idea, black or maybe cast iron.
